Do you sometimes get evil smells emanating from your shower drain? Particularly after driving down some bumpy roads? It's because the water in the u-trap under your shower pan gets shaken out and then allows grey water fumes to enter your bathroom. Our standard fix was to pour a cup of water down the drain to re-fill the u-trap. But what's the fun in that?
This mod solves that problem and also will stop the grey water tank backing up into your shower pan: Remove the u-trap and replace it with a Hepvo trap.
Warning: This is far and away the most awkward mod I've made to the trailer. Access is awful and you can barely see what you're doing.
Anyway this is what it looks like to start with:
Removing the rubber U-trap is easy - just unscrew the fitting from the shower drain and loosen the hose clamp that clamps the utrap to the 90 degree bend. Water in the U-trap will spill all over.
Next, you need to cut through the (vertical) riser about 3/8" above the floor level. I cut the horizontal pipe first because the 90 degree bend got in the way of my saw. Clean up the cut pipe to remove any burrs.
Now you have to assemble the Hepvo trap and associated ABS fittings. Sorry that I don't have pictures of this bit, but I was a little flustered at the time. What you need is (in order from the shower to the riser):
- The right-angle connector that comes with the Hepvo trap
- The Hepvo trap itself
- A 5" length of 1.5" white PVC tube (I cut mine from one of these)
- An 2" ABS compression fitting
- A 2" ABS street Ell
Start by gluing item 4 to item 5. Then assemble them all to do a dry fit. You need to get the length just right (the components slide in and out to make this easy) by pushing item 5 onto the riser and screwing item 1 into the shower drain. Tighten all the compression fittings and remove. Now comes the really hairy bit: Apply ABS cement to the open end of item 5, then reach in and push it onto the riser (which you can't see) while aligning Item 1 with the shower drain (which you can now tighten up). If all went well, it will now look like this:
and
There are 2 styles of Hepvo trap on the market. They only differ in the size of pipe that enters the trap. Since we're not using those bits, you can use either size.
I do not have a washroom sink, I installed a Hepvo trap valve in our galley sink, and if I did this mod to the shower (So I could plug the hole in the trailer bottom), then the only place an overflow would have to drain from on our 2018, is the roof vent pipe.
So at this point, going to give this mod a pass.
@Sharon_is_SAM I can attest to the fact (more than once) that the 2020 400 has a vent on the top of the gray tank which will spill water if you overfill it.
Another benefit of this mod is that you eliminate a possible freeze up issue in the winter and would no longer need to put antifreeze down that drain.
The overflow leak coming out the corroplast panel seen by some new TaB owners, may be the result of a poor connection between the vent pipe to tank connection on top of the gray water tank? I would think a purpose made overflow vent would have a tube coming down below the corroplast, like the fresh water tanks does. @TNOutback, can you see such a tube from the gray tank coming out the bottom?
