The catch-22 of abundant sunshine is the mighty hot cabin temperatures when trying to harvest sun rays via roof-top solar panel during hot weather. We've noticed that around half or more dispersed camping sites explored had a shaded area with adjacent sun for suitcase solar panels. Looking at the 200W panels with 40', 10awg extension.
But alas, we have a 2020 T@B 400 with no Zamp plug-in. What are our options for connecting the Renogy system (with controller) to batteries on a routine basis? I am assuming the wiring that might have gone to the Zamp plug is not there.
2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X Tucson, AZ
I purchased a 200W Renogy suitcase to supplement the 105W rooftop unit on my 320S.
I also purchased the quick-connect bulkhead connector shown below from Amazon. It comes with MC4 connectors on the outside. I just cut off the inside connectors and ran the wires to my solar controller which is mounted inside of the tub...near the batteries.
If your suitcase comes with its own controller, you can just connect the wires inside the connector directly to your battery (with an in-line fuse on the positive wire).
I also purchased an 8 Ga., 20' long extension cord to connect the suitcase to the connector.
However, after my first dispersed camping trip with this set-up, I realized that 20' is not really long enough, so I just bought a second 20 footer. I would recommend using 8 Ga. wire if you are going to run 40', to minimize heat loss. The second link is to a 40' extension cord set with MC4 connectors.
I hope this helps.
https://www.amazon.com/Cutting-Edge-Power-Weatherproof-Connectors/dp/B07MMWKR29/ref=sr_1_3?dchild=1&keywords=mc4+bulkhead+connector&qid=1623355956&sr=8-3
https://www.amazon.com/gp/product/B01L6OU74M/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&th=1
http://www.bigguytinytrailer.com/2019/01/23/zamp-connector-added-new-camper/
Madison, Wi
Here's an example using MC4 connectors. (There are two pairs because my pigtails are designed to allow modular use of my solar controller, but the concept is the same.)
Whatever you do just make sure to include a properly sized fuse between the controller and the battery.
https://www.amazon.com/ZAMP-SOLAR-ZS-SOLARPORT-Waterproof-Solar/dp/B07GNMPZZG/ref=sr_1_4?dchild=1&keywords=zamp+connector&qid=1623423611&sr=8-4
Mounting the port near the battery has the benefit of less voltage loss to the battery. The downside is drilling a hole next to the battery compartment through Aldez and plywood, then routing the wires to the junction box under the bed.
Mounting the port on the tub is easier as there is a junction box in the back of the tub down low where all the trailer 7 pin connector wiring routes through. The downside is the voltage loss getting that solar power to the battery.
I would suggest mounting it near the battery.
Here is a rough diagram showing the battery area and double false wall between the outside storage (blue X) area and the battery box (red Bat square)This divider has all the batrery and SC wires run in it. The blue box in the divider is the battery connection block (distribution box), which is the best point to connect a solar SAE or other connector. As Sec the connection plug from inside the storage box (blue arrow).
I think Victron recommends 30A fuses for that size system. I found for 30A fuses with pig tails, I could only get 12 awg pigtails. I felt this was okay since they were only 6" runs from the controller before connecting to the longer thicker wires.
