Modifcation to propane device (removal of regulator)
Hi,
I was thinking of getting an outdoor fire pit to hook up to the propane outlet on the TAB 320.  I emailed the company to check about removing the pressure regulated hose that comes with the unit.  They said it was removable at the threaded connection, but could not confirm the  functionality or safety and it should be done by a "propane expert".
Seems pretty straightforward to remove it and use a hose from the TAB's regulated source.  Should I be concerned about doing this myself.
Thank you
2025 360 CS
Southern Maryland
