Just finishing up installing two old guy grab bars and wanted to share lessons learned.
INTERIOR 320 ENTRY DOOR:
The wood door frame is flexible enough to make it an unreliable fastening point for a grab bar. My final wooden grab bar version buttresses against the outside wall to limit twisting, and bolts through the wood door frame. I installed a wood spacer between the wood door frame and the adjacent shelf unit to make the upper connection point of the grab bar stiffer (see photo). I then added a steel angle which nestles under the rubber gasket that surrounds the door frame (see photo) . Every one of these moves seemed necessary to make the grab bar sturdy.
1 ·
TV: 2004 Toyota Tacoma
Based in Tacoma, WA
If you searched all the forum Grab Bar Discussion you might have come across my Entry Door solution. And I fully agree with you that the door frame area mounts are not as solid as one would like . . .
However, since installing that grab bar I've found I'm not really using it as a grab bar . . . seems my body has learned how to approach / handle the exiting. Of all the mods completed the Entry Door Grab Bar is one of the least used, clearly not the worse/worthless mod but it has not worked out as a big success . . . a disappointment considering all the effort to come up with a solution.
For Grab Bars the one I placed outside of the shower and of course the one in the shower are by far some of the best mods completed . . . those two grab bars get a lot of use for their intended function.
Will be interesting to hear how your Entry Grab Bar works out . . . will your body also learn how to comfortably exit without needing it ?
Adventures: 51 Nights: 322 Towing Miles 41,200+
What was the intended function of the grab bar outside the shower, for which you get a lot of use?
We've had tons of use for your inside-shower bar - couldn't live without it.
At any rate, my solution was to remove the bolt-on steps and get a folding aluminum step, which is much more stable. I would recommend this to anyone who has mobility issues.
