PXLated said:Could it be the surge protector putting out heat in there Jenn?
The non-stop running of the WFCO converter's is normal as they will run to keep the converter cool when you are plugged into shore power. On the positive side of this if you're not hearing any squealing from the converter (it's the death knoll) or experiencing issues with your 12 volt accessories you're in good shape. And unless you have your battery turned off (via a battery switch or removing the fuse) there will be a certain amount of parasitic draw placed on it from things like the TV/DVD unit, your LED light circuitry, ALDE circuitry, etc.Sallybear5 said:Our power converter fan will not stop running when plugged into shore power. Had the Tab into service today and technician said the battery charge is great, He said the fan running is normal, but continually running has just started...this has not been the norm. Has anyone experienced this?
note: nothing else is in use. This continuous running of the fan did not start until after a lightning strike in the area which tripped the gfi.
