3 way refer won't start.
At home getting ready for a trip, pluged into 15 amp outlet. Turned on refer. Then a while later I unpluged from the 15 amps Without turning off the refer. I then pluged back into the garage 15 amps and the refer won't work. Is there a reset button? Advice?
    pthomas745 Posts: 4,645
    Won't start on electric?  Checked the usual circuit breaker suspects?  At the source and the trailer?
  • trimtab
    trimtab Posts: 237
    Electric,fuse good,source good, everything thing works fine in our 2020 320s..except refer won't cool. Changed to gas, guage in green, keeping fingers crossed. ( it is 89 degrees outside were the trailer is, maybe too hot to work?)
    Fingers crossed and give it some time....
  • Bayliss
    Bayliss Posts: 1,532
    edited June 2021
    @trimtab, did you check you AC wall outlets to confirm that they have power, especially the outlet for the refrigerator?  [The refrigerator outlet is under the sink on my 2019 320 S, but yours may be different.]
    Also, check to see if the GFCI on the trailer's exterior outlet (and inside as well) may have tripped.  That will cut the power to your trailer outlets.  Check the GFCI for the house outlet as well (assuming you plugged in to a GFCI protected circuit.)  It is possible that one of the GFCIs (house or trailer) tripped when you unplugged the 15 amp plug.
  • trimtab
    trimtab Posts: 237
    Hey Bayliss, on my way out to check some of those things...thanks
  • trimtab
    trimtab Posts: 237
    Checked it all, they were good.
  • trimtab
    trimtab Posts: 237
    I think it is just to infernally hot out and the refer gave up...
  • BrianZ
    BrianZ Posts: 1,770
    Is the trailer level?  How much time did you give it to cool down?
  • trimtab
    trimtab Posts: 237
    Level? Absolute.  Temp out there...down to 90..
  • trimtab
    trimtab Posts: 237
    !!!!  it's not cold but the alumanim tabs inside are cool, a bit, to the touch.
    Looks like 6 hours to get to this point.
  • trimtab
    trimtab Posts: 237
    same for the aluminium tabs...
    ScottG Posts: 5,688
    I have a different (older) model 3-way, but I suspect they are similar with regard to the basic wiring.
    Mine has three additional glass fuses located on top of the unit, accessed by removing the stove top. IIRC, one of those fuses is for the DC circuitry, another is for the DC heating element, and the third is for the AC heating element. If that third one is blown, the fridge won't cool on AC.
    If yours is still not cooling down, it might be worth seeing if you have those same fuses. Your fridge owner's manual should offer info as to their exact location.
  • trimtab
    trimtab Posts: 237
    It works...but in the heat it takes hours, 6-8 , to get cool.
