1. I had dealership run ground to battery per Nucamp instructions because of continuous blown fuses. I finally tested on weekend and panel seems good now, re re shore power. No blown fuses. (I did change one of the 3.15 af this time).
2. I drained less than 1/5 of gallon through drain plug. (I had not checked ahead of time how much was in expansion tank). Topped up and turned Alde on. Let run to warm up. Changed speed on circulation pump. After at least half hour, no heat to connectors. Very hot hoses at the boiler but going out from there hoses not heated. Suspect airlock or even pump not working.
3. Shut off panel on Sunday and last evening, Tuesday, realized the boiler was VERY warm but as above. I have not talked to dealership yet. I have turned off battery and unplugged shore power to see if boiler cools down. I will then turn all back on WITHOUT Alde panel and see if the boiler heats up which I suspect it should not. Once that is figured out I then need to see about circulation.
Anybody have similar issues?
0 ·
Have you set the temp to the highest setting? If not the pump will not come on. When the pump is running you can feel the vibration by placing your hand on it.
i assume you have the touch screen. Double check to see that it is set to heat not just hot water. The circulation pump only operates in the heat mode.
I have in the past set arrow on shower for hot water boost but have not touched it this year.
I believe I have two issues.
The digital control panel allows the pump to be run without activating the heat. With the pump on high speed, most of the trapped air (which you will almost certainly have if you drained the system and refilled by gravity alone) should eventually burp itself out through the expansion tank. When this happens you will probably need to top off the fluid in the tank.
The document I posted here describes the air bleeding process in greater detail.
If you increase the pump speed and set it to circulate without heat, there should be an audible whirring from the pump and some very obvious activity in the expansion tank. If this doesn't happen, your circulator pump may very well be not working.
Try this and see if things smooth out. Good luck and report back what happens.
I tried to find info on running pump without heat but found nothing so assumed heat had to be turned up. I had also looked for more detailed info on manually bleeding air besides just rocking the trailer up and down. I am so frustrated I am about to cry because I may have an expensive repair or replacement. There is NO Alde service anywhere in the province.
I will read through the docs you posted here. I also have a call in to Nucamp to find out if there was an error in the instructions they emailed re: burning fuses which I brought to my dealership service department.
Thank you or what you have provided so far.
@Mega, keeping the heat off is only a precaution as you bleed the air. You may very well have had sufficient glycol in the boiler core and therefore would not have damaged anything by running the heat. That doesn't mean there aren't other issues but they are not necessarily your fault.
I'm sorry I am so needy. No one around here to talk to in person to figure this all out.
You said you could not feel or hear the pump running. There are two wires that deliver power to the pump. One black probably negative And one red 12 volt power. By taking a test light clipped any ground and taking the point and piercing covering on the red you can test to see if there is power to the pump. If the light comes on there is power. If the pump is not running it’s likely the pump. If the test light doesn’t light I would look for a blown fuse.
If you have adjusted the speed on the pump. Be sure it is set clearly on one speed setting and not between two. If it were the pump may not work. I would also check each speed as well. Contacts on one or more speed may not be making contact.
It is very awkward to see the position of the dial on the pump because of hoses etc.
Troubleshooting is a systematic process, usually starting with the things that are easiest to check. This process assumes you are familiar with the basic operation of your digital control panel. If you are not, study up first. Nothing confounds troubleshooting more than operator error. ;-)
