Has anyone had a bump or horizontal imperfection appear in their floor?
Cleaning up after our latest 1500 mile excursion a in the 320,noticed  about a 6 inch long raised area right above the axle area, just in front of the converter.  It's not soft, doesn't run under bench area, and I can't find any signs of water intrusion.  Appears to be from bouncing as far as I can tell, are there metal cross members under the floor like the walls?
0 ·
Thanks Verna, but it's a 2015 bought used, so no dealer handy.
I found this post of the construction, so I think I'm feeling an aluminum cross member. We take our Outback on some rough roads, so I think it's most likely from that bouncing. I'll just continue to monitor at this point.
Will be curious to hear of any others with similar issue though.
Looks like I will contact Creed. It appears to be a bubble, possibly just the marmoleum flooring not adhering to the Azdel. I'm not concerned with how it looks, we keep a rug over the area, but if I can, I'd like repair and keep it from spreading.
