We are considering a generator primarily to recharge the batteries over cloudy weekends when solar cannot keep up. We want a generator with fuel flexibility so we don't have to tote gas cans around on each trip. We also figure if we're buying a generator, we might as well get one with enough oomph to power the AC. Gas and propane on the Champion 2500 both offer 2500 starting watts and 1850/1665 running watts, respectively. Is the propane powered wattage of 1665 enough to run the Cool Cat or would we need to jump to the Champion 3400 model?
0 ·
2020 Tacoma TRD Off-Road
Cat runs at 1330W. Once started, you won't be able to run much else. Starting is the big initial draw. An easy start device can help there as well.
Depending on what you regard as "essential" in your camping experience, this may fit the bill.
San Diego, CA
www.airbossone.com
Did you ever give the Champion 2500 dual fuel a try? I'm at the point of looking for the smallest genset I can carry to run the Coolcat - and would love the option to use propane. The specs per Champion seem to support it working for the Coolcat, even on propane - as the propane running watts and amps are listed as 1665W and 13.9A with a healthy starting 2500 watts.
Funny thing, just after writing the post to you, I saw a new post with a video from a forum member with a 2021 400 and the champion 2500 dual fuel installing a soft start because he couldn't get it to operate reliably without it. I just left a comment in his YouTube video wondering if the 16 gauge looking extension cord he had hooked up to it might be contributing to the starting issue. All that said, I've ordered the same 2500 champion dual fuel to be delivered in a couple of days from Lowe's hardware store, so I'll get to test it out for myself I guess. If it doesn't work I'll install a soft start as well, because it's really the right size generator for what I want, and I don't intend to ever run it with gasoline.
I installed my soft start last week and only made two bonehead moves - good performance for me. I’ll probably get the Champion Dual Fuel but still agonizing over the support for Honda in the community. The Honda with the propane conversion is twice the price of the Champion. Best I can tell the Honda is quieter, weighs 8 pounds more, and produces a little less power.
See thread noted below, but the installation sheet's step 1 called for moving and connecting "the white wire"....which for MY Coolcat, is actually the White/Blue wire. Working great now.
@rhyno @rrcbov
I installed a SoftStart yesterday, thought it was working, but realize it isn't starting the compressor at all. Unwired it, and the Coolcat is working normally. Either of you have the Coolcat actually cooling (i.e. turning on the compressor) with the SoftStart installed? If so, can you help me out with installation details?
If the SoftStart is running with just LED1 Green, then you have it working correctly. If LED2 remains on (Red) or LED1 goes to Red, then the compressor isn't running.
Details of my installation are in this thread:
https://tab-rv.vanillacommunity.com/discussion/13834/soft-start-installation#latest
Glad your install worked out well. I'm going to try to get my SoftStart installed after this heat wave breaks.
I received my 2500 Dual Fuel today, and after reading the 175 reviews on the Champion website, I was a bit apprehensive regarding it starting easily on propane. I'd say half of those reviews mention starting on propane, with most saying it was difficult to impossible, with about 10% saying it started easily.
I'm thrilled that I seem to have hit the lottery and have an easy starting generator.
During the very first 'priming pulls', it coughed to life on the third light pull. I continued to prime the 5 pulls, switched to Propane and it started on the second starting pull.
I ran it for about 15 minutes, shut it off and let it cool down, repeated the starting process and it started on the first starting pull.
If you haven't already read this on the Champion site (in the reviews), doing 10 priming pulls, then switching to Propane for the staring pull, seems to work for a few people reporting their experience - but I've been using Champion's instructions and priming with 5 pulls, then one quick starting pull with the dial set to Propane, and it seems to work every time.
There is lots of metal in the oil that came out of it after 5 hours. In hindsight, I would've have done an oil change after the first hour, then again after 5 if I thought there would be this much metal to get out of the engine.
All that being said, it runs smoothly and quietly, and starts easily everytime on propane. So I think it is going to be a good generator for me.
And while the generator is far from truly quiet when running on propane with a load (it does increase RPMs to provide the power needed to run the compressor), you can barely hear it in the T@B when the air conditioner is running (with the generator literally just 5 feet outside the bathroom area).
Have you seen any low volt issues yet with your setup or do you not run your gen in Eco mode?
I've only run the air conditioner for about an hour (in Eco Mode) in my driveway to test the system, and it ran flawlessly during that test. I have the hardwired version of the Hughes Watchdog. I did my testing with a 15' RV 30A cord to minimize potential voltage drop - though I have no back to back testing with a 25' cord to know if that mattered.
Would be nice to be able to see what the actual voltage the Champion is making when you're getting the Low Voltage error - to help isolate which piece of equipment is at fault (Watchdog or Champion).
I did use the Champion at 6,000 ft this week to run the microwave (which is only for a few minutes at a time), and it worked for that on propane, but was definitely louder at altitude than at home - but it did start and run which I wasn't certain it would without a different jet.
Thankfully, air conditioning was needed this week at that elevation in the NC Blue Ridge.
I had watched this YouTube test of the Dual Fuel 2500 and it stress tested the generator on propane (and gas), and the voltage held steady at 118V at 1,700 watts (starts propane test at about 12:30), and didn't drop voltage until he tries to overload it.
2021 T@B 400, 2018 Land Cruiser
Dallas, Texas
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view.” Edward Abbey
