I apparently had a rock hit the trim above my aluminum diamond plate on the front of my 2016 t@b 320. It looks like a slide in trim that fits in a channel. Has anyone had this happen and how difficult is it to fix on your own. Thanks for any assistance.
—Admin note—changed year of T@B to 2016, rather than 2026…..Verna, T@B Admin
As with the plastic strip that comes installed in the keder rails, I'm guessing that covers a track with several exposed screw heads. There are different styles of such trim, but you probably want something like this. They should snap out and snap in, so you shouldn't have to remove any other trim to get it replaced.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
ScottG I think I will order what you recommended and see if I can get it to work. It covers screws just like you described. Thanks for your help.
