Hi all! Does anyone know how to remove the front bezel on the Jensen cube? I want to gain access to the power lead so i can switch it and its annoying display off at night.
Thank you! Brent
2021 Tab 320s Boondock-2016 Toyota Venza V6 Toronto, Canada
I don't know if the new models differ, but my entire unit could be removed from the cabinet after removing four screws on the face. A wiring harness in the back of the unit included the main power line.
FYI you could dim the Jensen cube to zero then toggle the display on and off by tapping the power button. That's what we are doing until I get the time to install a power switch to kill the phantom draw off the batteries.
Success!..i was able to gently pry off the bezel quite easily and remove the 4 Robertson screws to take out the unit. I will be putting a small toggle switch on the panel to the left of the radio with the toggle out of sight in the small cubby there...thanks for all the help everyone!
Brent
Yoshi_TAB, I used a toggle switch i had kicking around. I drilled a hole the size of the switch shank and inserted it from behind with wires already attached. Because the switch shank was not long enough, i just epoxied it in, cut the red wire and crimped the switch wires to the two red wires...simple but effective! Here is the pics🙂
https://jensenmobile.com/user-manuals.html
Toronto, Canada
Brent
Toronto, Canada
Brent
Toronto, Canada
Brent
Toronto, Canada
Toronto, Canada
Do you have a picture of the switch or brand/part number you used? I also would like to have the light completely off at night. Thank you
Southern Maryland
Here is the pics🙂
Toronto, Canada
