Fiddlinmike
Member Posts: 17
Hello everyone. We have a 2019 Tab 320 with a factory installed solar panel. The Tab came with an Ultrapower R24 marine battery that has a sticker on it saying its reserve capacity is 125 minutes at 25 amps.
We are the people for whom these stock batteries are intended. We typically camp with electric hook-ups, and our dry camping rarely extends past a day. We also have the luxury of storing the 320 in our garage. So it’s nearly always connected to power. Batteries and solar power don’t often figure into our camping experience.
For 3 days this week we went dry camping, with good sun exposure. We have no battery monitor, so we started cautiously using the battery - no Alde, fridge on gas, limited use of lights and fan. The solar panel seemed to have no trouble keeping the battery fully charged with our conscious attention to consumption. On the 3rd night, I decided to push it a little. We ended the sun-day with a battery over 13 volts. That night we ran the MaxxFan all night at maybe 40%, used cabin reading lights maybe 3 hours, used the water pump for flushing and brushing teeth but little else. We also charged an iPad and an iPhone. In the morning I read the battery charge using the Victron Connect app on our solar controller - it was 11.97. I was surprised it was that low - we hit the 50% capacity limit from what I understand. On reflection maybe that’s what I should have expected. I know you don’t want to regularly run the battery this low if you don’t have to.
The purpose of my post is to get an interpretation of the history report I’m seeing on my Victron app…
What scares me is the “low” battery voltage readings near 10 volts on two of the days. If that’s right, wouldn’t I have ruined my battery? The column labeled “3 days ago” was the day that ended with a full battery and started my aggressive experiment with our overnight power use. The column labeled “2 days ago” was the morning I awoke having drawn our battery from +13 volts to 11.97 volts and towed the camper home. Back at home I had a full +13 volt charge, and all is apparently well. Every time I’ve checked the battery with a voltmeter at the battery terminals it has registered the same as the voltage indicated on the Victron app.
So, what accounts for the low voltage readings? Also,what accounts for the “consumption readings” of 10Wh in 3 of the columns? If our bulk and absorption periods totaled about 170Wh in “3 days ago” does that give me a rough indication of how much energy I drew from the battery during the prior day (assuming no other charging from A/C or the tow vehicle and low power use while charging with the solar panel)? Does the low bulk and adsorption total on the “2 days ago” indicate I was getting a significant charge from the tow vehicle (the sun was bright driving south that day)?
Thanks for your thoughts on this!
I saw where one can apply user settings for charging through the Victron Connect App, but I can’t find any recommended settings for my Ultrapower R24 battery. After extensive searching, I emailed a dealer, but no response. So, I’ve never changed the settings from the factory default (Gel Victron deep discharge(2)). Maybe there are better generic lead-acid settings I should use.
I understand voltage readings during discharge and use are not the same as resting - I’m hoping that means that the actual resting voltage across the battery terminals never actually dropped to 10 volts, but I wonder what the point of the high and low readings are in that case. I’m happy to disregard them as a casual user, unless I need them for something.
Thanks for the tip on rapid discharge. After thinking about it the overnight drop seems about right for my battery, but still the 10V thing bothered me, and I don’t understand the “consumption” line, and the way I look at the bulk charging numbers is telling me I had solar capacity to spare in the early days of my trip.
"Consumption (only on 100/20 models and smaller)
Shows the energy consumed by loads connected to the load output terminal."
So, I'm curious what loads you(or NüCamp) have connected to the load terminals on your controller. I'm not familiar with how NüCamp wires them, but we don't have anything connected there, since all our loads go through our Victron battery monitor shunt.
Regarding the History page in the app showing the total Wh of solar power each day, I've been interpreting that as the total power generated & used to recharge/maintain the battery each day. Also, if you divide that number by 12 (volts), you'll have the number of Amp-Hours (AH) you've needed each day, which you could use to estimate your average daily power needs. On our first trip using solar, we averaged around 18AH per day, using propane for both fridge & Alde, with other typical usage for lights, water pump, charging cell phones, and occasional use of a cell phone signal booster.
In your case, your fan might have been the biggest draw. For example, if it was a 60 watt model, divide by 12 and that's a 5 amp draw; but if you used only 40%, that's still 2 amps. Ten hours of usage per day would then consume 20 AH, or 80% of your available 25 AH of battery power before you fall below 12V/50%. The 5 AH remaining won't go very far.
This may be getting off the topic a bit, but some of us have modified our stock ceiling fans to reduce both power consumption & noise while saving power by running it at a very low speed using a PWM controller device. I agree with @Sharon_is_SAM, that you could benefit from a larger battery, if you want to avoid running your battery down. I doubt you did any major damage, by the way, but might have shortened battery life a little bit. We replaced our stock battery with a 150AH golf cart battery & can get by with a single 100W panel. These mods are documented here, if you search for them.
A responder on the Victron forum told me that the measurements in the “consumption” line are phantom readings from the load output and they can be ignored. That makes sense to me because we have nothing wired to the load terminals on our controller.
The other information you provided makes me feel much better about my understanding of what’s going on with our consumption and production - it’s all starting to make sense and appears in line with your experience. You’re dead on with the fan observation. Our battery just doesn’t have much capacity and otherwise my calculations line up exactly with yours.
I’ve convinced myself that the 10V minimum reading in the Battery max and min area must be some kind of instantaneous measurement affected by load or generation, and not at all a representation of the actual resting state of the battery. It makes no sense to me that we could have either drawn our battery that low, or recovered from it if we had. As I said, until that one evening we barely used the battery, and it looks to me like our bulk and absorption charging regularly replenished the battery long before we lost sun power. Do you have an opinion on that?
I really appreciate everyone responding to these questions. I’m going to try to do the same if I can catch someone else’s question before the experts chime in!
PS… we’re from Abingdon, Virginia - I’ll put that in my sig.
