2016 T@B - I did a search and didn't see answers for this topic
1. I was told that a dead battery could eventually impact other devices in the T@B. I must have waited too long because now my brake controller is being inconsistent (display flickers "N.C" not connected) and my frig doesn't work. I've got a Prodigy RV brake controller. I'm not sure if the trailer battery impacts it or not. I've since replaced my battery and noticed a few "N.C." display flickers on the short drive to storage. Have I ruined my brake controller and refrigerator forever?
2. Can I use a 110 adapter and connect my 30 amp power cord to the plug in my storage facility instead of a trickle charger? Will the 110 connection damage anything? I would turn off my battery connect switch so smoke/carbon monoxide detector and radio is turned off. Would a trickle charger be better?
0 ·
This is how most owners plug in their campers at home (where RV-specific outlets are uncommon) and also in campgrounds that offer only 20 amp service. When the camper is plugged in, the built-in battery charger will serve the same purpose as your trickle charger.
The T@B operates on 120 volts regardless of whether you are plugged into a special 30A RV outlet or a "regular" outlet (with the help of an adapter). The only difference is the "regular" outlet will be limited to 15A or 20A, so you may not have enough power to run your heat, air conditioning, refrigerator, and espresso machine at the same time. ;-)
I have the Prodigy brake control system and I’m pretty sure it’s powered through your 7-pin connector’s 12v line from the tow vehicle - not related to your TAB battery. If you are getting the n.c. display it’s likely because you don’t have a great connection through the 7-pin connector or somewhere else along the 12V line in your tow vehicle. I had a problem initially with the 12V line’s fuse near the tow vehicle battery. I was constantly losing connection until I put a slightly larger fuse in the line. I haven’t had a problem since. If you’re getting intermittent .c and n.c., I suspect a weak/bad connection from your tow vehicle battery to the TAB along or in the 7-pin connector.
Bottom line, I don’t think your dead TAB battery had any effect on your Prodigy system.
When plugged into 'shore power' be it campground 30A or home/storage 20A to allow the T@B Power Center to charge the battery the Battery Cut-Off Switch must be set to "On" .
Once the Power Center senses the battery is fully charged it will automatically go into a 'trickle charge'.
Prodigy P2 web-site:
Adventures: 58 Nights: 405 Towing Miles 50,180
