I am getting a tire pressure monitoring system for my t@b 400 and realize I don't know what the recommended psi is? how can I find out-I need to check my tires and have inflated to the proper psi when I set it up I know what it is for my truck 35-38 psi but no idea what is recommended for the trailer tires-Kay-I feel like such a newbie-I got a electronic tire pressure checker but have not used it yet.
0 ·
The tire sidewall, however, is a maximum tire pressure not the "recommended" one and you would vary that figure depending on your load and specific use. As I'm not an expert, perhaps this post from TireTrack might be of help from an "expert". Of note is this paragraph although the entire post is of value:
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=8
-Kay
asked by: Denis B
Expert Reply:
When inflating trailer tires the recommendation is to inflate the tire to the max tire pressure listed on the sidewall when the tires are cold. So if your max pressure is 65 then that is what you would need to inflate to when cold. The increased pressure when hot is normal.
If you don't inflate to max pressure the tires will not get their full capacity and heat will build up which will cause premature failure.
2013 Tundra TRD 5.7L
Massachusetts
These guys nailed it in their explanation of COLD TIRE PRESSURE
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=73
This is from the Unofficial Guide definitions section:
· Cold Tire Pressure: This appears on the tire sidewall where it states the Maximum PSI. Most of us understand this to mean at first light when the car hasn’t been driven anywhere as driving heats up the tires and the air inside. Engineers would more specifically say that the MAX is the inside tire pressure when the ambient temperature is at the index value of 68-deg F and that this changes by 2% for every 10-degree of temperature change. For the rest of us this means that since the vehicle rests on the tires, and tires are supported by the air inside, when it’s hot out the air expands and when its cool, the air contracts. If you drive a perfectly inflated vehicle from Florida at 70-degrees average temperature to Canada with a 45-degree average temperature, the tire will need more air when measured cold the following morning because cooler temperatures are contracting the air volume and the air volume is what keeps the tire inflated. The reverse is true when you go in the opposite direction and you’d need to let some air out when you got to Florida to stay at your MAX rating. This is why you check tire pressure seasonally.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
2019 Toyota Tacoma
Asheville, NC
"Don't postpone joy!"
I've been using the "air hawk" inflator. It's one of those "as seen on tv" items but I love it. I've had it for at least 6 years and it still works great and it gets alot of use.
