Site access issues - certificate expiry
I'm not sure if I'm the only one getting this error message when using Firefox or DuckDuckGo to access the forum:
"Websites prove their identity via certificates, which are valid for a set time period. The certificate for tabforum.nucamprv.com expired on 7/23/2021.
Error code: SEC_ERROR_EXPIRED_CERTIFICATE"
I've gotten this on both my laptop and desktop and in both cases, after checking and re-syncing the computer clock. The MS Edger browser does not return the message however, and connects to the forum normally.
    No problem here using Safari via the Vanilla url.  Are you accessing via Vanilla or via the nuCamp website?
    I'm not sure why you're using that domain, but I use: tab-rv.vanillacommunity.com
    Try that?
  • CharlieRNCharlieRN Member Posts: 438
    edited July 2021
    It's odd - I did not change the domain, somehow Firefox/DuckDuckGo chose it and I didn't realize it was not what I had been using. No problems using  tab-rv.vanillacommunity.com.
    Thanks for the suggestion
    I'll guess that error means an expired certificate at nuCamp.
