Shower pan is cracked around the drain, where is that water going?
Omniphil
Member Posts: 50
(T@B 320S)- We are starting to get cracks around the outside edge of the metal shower drain. I am assuming that water seeping in there isn't going into the main drain as that seems to be only down inside the drain.
What is under the shower pan and where would water potentially go if the pan was cracked? If it drains outside the camper somewhere that isn't a huge deal, but if there is a wood floor under there or something that could get water damaged that is certainly something to be concerned about...
I know we have a plastic covering of sorts under the trailer, so it's not going directly to the ground, but water getting down to that plastic liner should eventually make its way to the ground vs getting inside the camper somewhere...
Please provide details of your trailer model and year and significant changes in your information or signature line so others can comment specifically on your situation.Snohomish WA, 2015 Diesel Grand Cherokee
managed by VE Smart Network0 -
This is a 2018 T@B 320S. No significant changes at all0
This thread has a picture of what is under the shower pan. https://tab-rv.vanillacommunity.com/discussion/5025/just-fyi-on-what-is-under-the-shower-toilet-floor
Here, too. https://tab-rv.vanillacommunity.com/discussion/comment/82182#Comment_82182Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0 -
Ok, so there is certainly wood flooring under there. We'll have to get some flex tape/flex seal or something to patch it up it sounds like... Replacing the whole floor seems like a daunting project...0
@Omniphil - Verna had a 2014. Not sure if there is still wood in that area. Email Help@nucamprv.com to find out.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Yes, my 2014 had plywood in the floor as Azdel had not been introduced in the Pleasant Valley Teardrops Trailers at that time. There was no composite of any kind in the floor. Vinyl flooring on top of plywood.Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”0
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
