Looking for dimensions on T@B 2021 320S Kitchen cabinets
Does anybody here know what the dimensions of the inside measurements of the two undersink kitchen cabinets installed in the 2021 T@B 320S? I suppose that the measurements may be the same for earlier years, but if you have measured the inside dimensions of a 2021, I would really appreciate getting that data. I'm wanting to install slideout drawers shortly after we pick up the new T@B next week, but want to make sure I order the correct items.
Thanks in advance.
  • mntrails
    mntrails Member Posts: 144
    The inside dimensions for the top cabinet are 20" wide x 14-1/4" high x 19-5/8" deep. The sink trap does hang down inside.
    The bottom is the same width/height but the shortest depth at the bottom is 13-3/4". The wall curves outward so the top of the bottom cabinet will be deeper. Here's one picture for you to look at - you'll need to avoid the hinges as well.  I unfortunately don't have the measurement of how far they stick out.
  • Ponzi
    Ponzi Member Posts: 26
    Thanks very much for this good info!
  • Towhee
    Towhee Member Posts: 54
    Hinges stick out about twoi nches
  • Kiosk
    Kiosk Member Posts: 34
    Can you post results, details of drawer, slide out when done? Super idea!
    Are you doing top and bottom?
    thanks
    @Ponzi - can you reply?
