Looking for dimensions on T@B 2021 320S Kitchen cabinets
Ponzi
Member Posts: 26
Does anybody here know what the dimensions of the inside measurements of the two undersink kitchen cabinets installed in the 2021 T@B 320S? I suppose that the measurements may be the same for earlier years, but if you have measured the inside dimensions of a 2021, I would really appreciate getting that data. I'm wanting to install slideout drawers shortly after we pick up the new T@B next week, but want to make sure I order the correct items.
Thanks in advance.
The inside dimensions for the top cabinet are 20" wide x 14-1/4" high x 19-5/8" deep. The sink trap does hang down inside.
The bottom is the same width/height but the shortest depth at the bottom is 13-3/4". The wall curves outward so the top of the bottom cabinet will be deeper. Here's one picture for you to look at - you'll need to avoid the hinges as well. I unfortunately don't have the measurement of how far they stick out.
2021 T@B 320S Boondock - 2018 Toyota 4Runner0 -
Thanks very much for this good info!0
Hinges stick out about twoi nches0
Can you post results, details of drawer, slide out when done? Super idea!
Are you doing top and bottom?
thanks0 -
