Yet another single bed setup configuration
alanerickson
Member Posts: 15
Seems like a lot of them use a custom cushion which I didn't want to mess around with. Made this folding L table with locking brackets that uses a standard cushion. Table was opened up to make it lighter but that's not strictly necessary. It's held in place by hook and loop. Loop faces down and attaches to the utility access cover. Just a couple of staples will hold it. Loop stores under cushion when not in use. Pictures are a little out of order but hopefully you get the idea.
And I picked up a second Laguna table bracket and mounted that just to get it a little further out of the way to make getting out a little easier. The table can go in its' original location when the bed is down, but it's right there in a not very good location.
How does it attach for stability after you set it in place? Just Velcro?0
Yes, just velcro. As long as you hold it up against the bench (which the Velcro does) there is no way for it to tip or move.1
Do the notches on the edge of the top serve a purpose? Cutting out the elongated holes on each plate serves to lighten the addition? Would you have cut holes less now that you’ve used it for a while?Wander Yonder….
🌻 Denise
🐾 Tyson
Home Base: Utah
TV: 2018 4Runner Limited
TT: 2020 T@b 320s Boondock Edge0 -
@MountainMade @alanerickson has not been active since March. If you precede an “@“ before a members name, they may receive a notification. A private message will get her attention, too.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
