2017 320S As noted by many, the area behind the sofa is a great storage area - at least on the right hand (door ) side. Problem, I'm a bit short on the reach, even pulling it forward as far as it will go I cannot reach the bottom behind the Alde. I can get the sofa past the window on the door side but it is just a 1/2 or so too high on the other side. Has anyone opened the sofa and worked back to get to the wood backing then, cut off enough to get to to lay flat ? If so, what problems did you encounter ?
0 ·
TV 2025 Telluride X Type
https://youtu.be/Tc3e7318hw0
