The drain pipe under the kitchen sink is leaking when I run water. I had this problem before, and was able to hand tighten it, but now I'm not having any luck. I tried using plumber's tape on the threads, but it doesn't seem to help. The leak seems to be just below the threaded pipe. What can I try next? A photo is attached with the area of the leak marked.
Disclosure--I have very little experience with plumbing, but I'm willing to try!
The install was easy, no cutting required, except to fit the new tail pipe to the correct length for fitting. Here is a link to the HevPo fitting: https://hepvo.com/
Here is a photo showing the new fitting installed:
