We are new owners of a t@b 320. Earlier this summer, we had water on the floor of our t@b after travelling in the rain. It never happens when the t@b is stationary. I assumed it was coming up through the wheel wells. We took it to a t@b dealer in Moncton (Canada) and they assessed all the hoses and plumbing and even took a hose to the outside and underneath but could not determine how water is turning up on the floor. It occurred a second time while traveling in the rain and we are unable to determine how water is getting in. Has anyone else experienced this with the new 2021 320 t@b? We thought it might be coming in through the door but it appears to have a good seal. Again it only happens when we travel on rain days.
0 ·
We have water spotting in the back behind the AC which NuCamp says was from the AC, but that only has run once since we had it.
2020 TAB 320S Boondock Lite
TV: 2018 Jeep Grand Cherokee
@SusanD - I recall seeing your posts around for awhile. If you have an earlier 2021 T@B 320S, there was a problem with the mechanism used to hold the A/C unit in place. The fastener to hold the webbing that keeps the unit it place could easily pull out and the A/C unit would slide forward thus mis-aligning the floor holes and the vents and let water in. If you haven't had the update applied, I would strongly consider getting it. You can tell by looking at the front of the A/C unit from the inside. If there is a piece of metal angle screwed to the floor at the front, then you have the fix. If you don't and only see a piece of blue webbing, then you (probably) don't.
Good luck!
TV 2025 Telluride X Type
Southern Maryland
https://tab-rv.vanillacommunity.com/discussion/6393/maintenance-notices#latest
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
