Watch out for allowing water to accumulate in the base of the Nautilus compartment. I accidentally left a slow drip on my city water connection and rather than going down the compartment’s drain hole, the water slipped through the Nautilus base somewhere and leaked onto the floor of the trailer at the rear. Under the bed, into the outside storage compartment. The Nautilus compartment sits on top of the floor, so leaks spread. I’m going to add caulk along the base of the compartment, and make darn sure from now on that my connections are drip-free.
1 ·
Good to know. I haven't had that problem (yet) but will be careful to inspect that area for potential leaks.
Are you certain you don't have a leak in one of the connections behind the Nautilus panel - visible by lifting the bed platform and exposing the Alde system area?
2020 Tacoma TRD Off-Road
Problem Statement: water can leak into the cabin of the camper via the nautilus compartment in at least two places, (1) the low point drains, and (2) the gap between the nautilus housing and the camper outer wall.
This problem occurs whenever water collects in the pan of the nautilus compartment and can be replicated by simply pouring a cup of water at either of the locations listed in the problem statement.
Solution: Caulk everything surrounding the low point drains. Caulk the gap between the housing and camper exterior. Let sit for 24
hours before water testing.
Because of other minor leaks in the water pipes I have found, I check everything during each trip with the system pressurized with water. The plastic Pex joints should be brass! In addition to the Nautilus leak I've found 3 other area with (very) minor leaks at the couplings.
managed by VE Smart Network
I would not seal around the low point drains where they go through the bottom part either, let the water out, so it does not leak into the TaB.
