New Trailer Jack Wheel Conversion
My driveway is made of pavers. The plastic wheel rolls roughly over them and it is an up hill push to put the T@B in the garage. I looked around and found an eight inch pneumatic caster wheel. It will handle 250 lbs. I then took a square foot plate and attached the caster to it. I am now able to swap out wheels and roll the T@B almost effortlessly around.
The only real gotcha is that it will not lower far enough onto the tow ball, so I have to swap out wheels or use a jack when I am ready to hitch the trailer up. A small price to pay for convenience!
"Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
  • Cyclonic
    Cyclonic Member Posts: 1,232
    Looks like a nice solution to your problem.  Not really fond of the plastic wheel either.
    Sterling, VA
  • Dalehelman
    If it does what you want it to that's what counts.
    I love it when a plan comes together.
    1. Hash  T@B Fun
  • Dalehelman
    Your project got me thinking. I also hate those cheep hard plastic wheels. The pneumatic was not quite right for my need either. I did find a 6" direct replacement hard rubber actually poly wheel with ball bearing axel. Thanks your project helped be find an answer to a problem I did not even know I had.image
    1. Hash  T@B Fun
  • jdargis
    jdargis Member Posts: 305
    What brand and where did you purchase the poly wheel?
  • Michigan_Mike
    Here you go!
    http://www.accesscasters.com/ac-2712-6-swivel-plate-caster-poly-on-poly-wheel-900-lb-capacity.aspx
  • Dalehelman
    Harbor Freight $14.99 with a 20% off coupon.
    1. Hash  T@B Fun
  • jdargis
    Thanks for the info.
    Jeff
  • Cyclonic
    Gotta love Harbor Freight.  We live literally blocks from one.  My wife used free coupons for all of her stocking stuffers last year :)
    Sterling, VA
  • larrygon
    larrygon Member Posts: 255
    I initially thought about a poly wheel but I needed a pneumatic tire so it would not get stuck between the pavers. Still looking for an inexpensive 6 inch pneumatic tire caster. Harbor Freight had the 8 inch pneumatics for $14.99.
  • Michigan_Mike
    I had an 8" inflatable tire on my 5-wide Little Guy trailer and if you are in loose or sandy soil this type of adaptation is best since you can move the trailer around with ease.  The issue as noted above is in your ability to raise the trailer up and get the tire on.....
    I solved that issue by fabricating an additional stand (with attached jockey wheel) that was welded inside the trailer frame behind the tongue.  This was pinned into place and once the trailer was jacked up high enough I unpinned the jockey wheel, rotated it down and pinned it back into position and lowered the trailer tongue jack down until all weight was on the portable jockey wheel assembly.  this type of set-up is doable and the trailer is easily maneuverable in loose, sandy soil.
  • Dalehelman
    Do you have any pictures?
    1. Hash  T@B Fun
  • JandJ92010
    JandJ92010 Member Posts: 304
    Tractor Supply has a pretty good selection of casters also.
  • Mercator
    Mercator Member Posts: 237
    Would this one fit as a straight replacement for the plastic wheel?  If so, I think I would switch for the pneumatic tire too.
    Ray and Vida Barrick
    (formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
    Toronto ON Canada
  • Dalehelman
    Most of the time with pneumatic wheel and tire combinations the 6" is referring to wheel diameter not tire. It's unclear about axel size 3/8 bearing is to small needs to be 1/2". Measurements are not very clear.
    1. Hash  T@B Fun
  • Dalehelman
    Pneumatic tires work fine but if they loose air and they do over time they are useless.
    1. Hash  T@B Fun
  • jdargis
    Also, looking at the specs, it has a 150 lb dynamic load rating, which the tongue weight of a T&B starts at around 150 lb unloaded.
  • MN_Jim
    MN_Jim Member Posts: 3
    The little trailer jack wheel sank in the mud, so I purchased 2 additional wheels/bushings online and an 1/2 x 8" bolt locally.
  • dsatwork
    dsatwork Member Posts: 744
    Wow that is clever
    Trailer jack training wheels!
  • Michigan_Mike
    This still doesn't solve the issue of mud or an uneven surface.  An inflated rubber jockey wheel that can handle the weight will spread out better and does distribute weight much more evenly.
  • Dalehelman
    Until it's not inflated
    1. Hash  T@B Fun
  • Pika1
    Pika1 Member Posts: 29
    @dalehelman, do you have the item # for the wheel from Harbor Freight? Side note: #1, holding tank mod is great, #2 cold air deflector mod for ac using old yard sale sign. Works great.
  • Dalehelman
            HFT # 61651 if I remember correctly
    1. Hash  T@B Fun
  • TabberJohn
    TabberJohn Member Posts: 588
    edited August 2017
    Access Casters also lists a 6" no-flat pneumatic (250lbs) that looks like a good candidate:
    http://www.accesscasters.com/6anf62-6-no-flat-pneumatic-wheel.aspx
  • Pika1
    @dalehelman, thanks.
    Wow, your Amazon delivery is uber quick.  Matter of hours.  I am impressed.
  • RedDoorGals
    RedDoorGals Member Posts: 36
    edited October 2017
    Folks: I'm looking for reference item #'s or sources for any of the solid rubber "extra" 6" wheels. The HF reference number listed by Dalehelman takes me to an item which includes the caster. They list an 8" tire; but not a 6" (that I can find).  The 6" solid tires I've found with random web searches turn up wheelbarrow tires rated for only 50 lbs.  Thanks Team!!
    2018 T@B CS-S; pulled by a 2010 Toyota Tacoma v6
  • RedDoorGals
  • Dalehelman
    Up grade thanks to trikepete.https://m.harborfreight.com/6-in-rubber-heavy-duty-rigid-caster-61647.html
    1. Hash  T@B Fun
  • TerryV6
    TerryV6 Member Posts: 1,101
    Is this kind of tire better than the original?
    2016 NuCamp 320 T@B Max S
    T@bbey  Road
    Appleton,  WI
