Fan-Tastic Vent failure
Greetings-
The fan/vent in the bathroom of our 2020 T@B 400 BDL stopped working this weekend. No warning, no electrical smell or obvious broken wiring connections. Has anyone else had issues with their Model 600 EZ-Breeze fan? Thanks!
2020 T@B 400 Boondock Lite behind our 2014 GMC Sierra. Homeport is Olympia WA USA.
  • JohnDanielsCPA
    JohnDanielsCPA Member Posts: 238
    The fuse holder may have come loose.  Recheck that.  Happened to me last year.
    2022 T@B 400 BD
    2019 Ford F-150 3.5L Ecoboost with Long Bed
  • OlyCampers
    OlyCampers Member Posts: 23
    @JohnDanielsCPA Thanks for that tip. While the fuse holder on the Fan-Tastic fan in the main cabin is visible, I don't see a fuse on the fan in the bathroom. Can you point me towards it?
  • Horigan
    Horigan Member Posts: 927
    Check the fuse panel on the converter.
    Rich
    2019 T@b 400
    Bellingham WA
  • Verna
    Verna Member Posts: 6,876
    @OlyCampers, if you use the search box (upper right of this page) and type in “T@B 400 fan” you will find a number of other posts concerning the problems with this fan.
    The “normal” solution is to upgrade your other roof top fan with a 10 Speed Fantastic Fan or a MaxAire 10+ speed fan. Then you replace the current bathroom fan with the 3-speed fan you removed. If you have already updated your main roof top fan, a three speed Fantastic fan would last a long time in your bathroom.
