T@B 400 table attachment hardware broken
SeaLaVieSeaLaVie Member Posts: 47
edited October 2021 in Trailer & Towing
I have been having trouble with one of the attachment clips on my dinette table coming loose from the rail that it it's supposed to hang on to. Occasionally I will arrive somewhere and the table will be laying on the floor having come loose from the wall! Is this attachment hardware a standard item I can find on Amazon?
2018 T@B 400
  • dnordahl1dnordahl1 Member Posts: 15
    I'm going to give this a bump because I'm also wondering where to source these.
    2019 Nucamp Tab 400, 2007 Toyota Tundra 4.7L, 4wd SR5
    edited October 2021
    I do not think you will find the table hardware on Amazon, I believe nüCamp sources the brackets and the new table (from 2021 models and up)  from Europe. I have seen this table system demonstrated on Europe RV show videos.
    Is the table coming off the wall bracket, or has the wall bracket come loose off the front mounting wall?  It takes a little finesse to get the table brackets to click in locked position on the wall mounting rail.  You need to get the table catches set correctly.  You can test to see if the table is locked on by pulling up in it.
    Getting additional table hardware can be sourced from nüCamp via a dealer.  See the new parts order from at the top of this Forum Discussion list.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,931
    Thanks for the link, but I'm not having any issues with my table fortunately.  I was mainly looking for extra hinge clips to use to build a small, easily removable shelf to sit under the table and to rest slightly over the electrical outlets (and still leaving a gap for the Alde heat).  I'm hesitant to order more parts from Nucamp from my dealer if I can find them online because it seems like it's much more expensive and a bit of a hassle.  I just ordered a replacement tail light for one I discovered was broken by the previous owner and taking on water, and the cost was over 4 times what the same part is on Amazon or eTrailer.
  • Michael_GodshallMichael_Godshall Member Posts: 21
    I order my table hardware directly from Lagun USA,  my 2022 shipped without the table hardware and my dealer was not able to tell me when I could expect it and they didn’t offer to obtain it for me.
    Michael Godshall
    Holland PA
    2022 T@B 320S Boondock
    TV: 2018 F150
