3 way fridge 12V voltage level - SOLVED
webers3
Member Posts: 444
Removed the 3 way fridge and wanted to use the 12v line that went to the 3 way fridge to power the new 12v fridge but when I measured the voltage on the 12v line it shows 11.3v even though the battery voltage is at 12.7v. I measured the voltage at the battery and at one of the 12v outlets inside to verify the 12.7v. Any explanation why the voltage on the fridge line is low?
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut
Can't explain except to say that we removed our 3-way fridge in favor of a 12V slide-out chest and used the existing 12V line. With a rested battery, we get the same voltage there as at the battery (or any other place). Works great!
You either have a small resistance short in that wire, or a bad splice/connection point. Try disconnecting the wire from the power converter at the fuse connection, measure the voltage at the fuse load side, if it is 12.x VDC, then next, cut off the wire ends and re connect them, if still getting a voltage drop, trace the wire, there is an issue somewhere along the wire run.cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
@webers3 ... I did not trace the wire, but when testing my battery draw I checked each circuit individually and didn't find anything else but the fridge on F4. That's also what I've read in different places. And yes, F4 is an auto style fuse.(the 20amp fuse at F4 is in upside-down, but this picture shows its location)
Well, that's embarrassing, it was the fuse. It didn't occur to me to check it to begin with because there was voltage, although lower, on that line. So I don't understand why there was voltage on the fridge line with the fuse out.2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut0
Voltage was likely due to feedback on the ground circuit.
Brad2020 400 BDL aka "Boonie"
Concord, NC0 -
I'm sure it is fine, sorry to create the concern.
Concord, NC0 -
Glad to hear you worked it out. Out of curiosity, which slot was your fridge fuse in?
@webers3
That phantom 11.3v was probably due to the tiny current which powers the “red fuse is blown” LED in the WFCO. The LED is usually shorted out by the fuse, but when that’s blown a trickle current runs through the light and then to the fridge or other load.Charles & Judy, Santa Cruz, CA
2018 T@B 320 CS-S; Alde 3020; 4 cyl 2020 Subaru Outback Onyx XT2 -
webers3 said:Now I need some cabinet making skills so I can do what you didMy cabinet making skills are all but nonexistent. I faked it by repurposing the wood from when I pulled out some of the rear cabinetry. The face panel on my pullout is the lid for the rear storage compartment cut down to fit.
Glad it worked out for you. What model did you replace it with?0
webers3 said:@Viajero Replacing it with ICECO JP50, have used it for over a year and so far so good. Set the temp and forget it, unlike the 3 wayThe JP50 (and JP 30, and JP 40) all seem to be 28.5" in length, while the Norcold Fridge requires 25 5/8" - to fit the IECO, did you have to cut the cabinet or did it fit?
Seattle, WA -> Palm Springs, CA0 -
@AldebaranJill I didn't have to cut any part of the cabinet but I did have to take off the ICECO handles2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut0
Thank you!!webers3 said:@AldebaranJill I didn't have to cut any part of the cabinet but I did have to take off the ICECO handles2013 MAXX T@B towed by a 2015 Volvo S60 5 CYL AWD Sedan
