My Alde control panel is not receiving power (no green LED) when only on trailer battery power. All other DC appliances are functioning properly (fans, pumps, lights, radio, etc.) on trailer battery power. The battery panel is reporting 13.5 volts. The Alde panel functions properly on shore power and when connected to the tow vehicle.
Any ideas why the Alde panel would work on DC from the TV, but not directly from the trailer battery, which seems fully functional?
0 ·
cheers.
Are you sure the 'green light' is off when on battery . . . .
could be very dim - - - sometimes the plastic touch cover slips down covering the green light - - -
covered by touch plastic
If control panel back light was off (dark mode) control panel would seen dead
The light is visible and the screen powers on when connected to the TV and under the same conditions otherwise.
No. The electrical path from the tow vehicle to the converter to the Alde is the same as that from the battery to the converter to the Alde. I can think of no explanation for those particular symptoms other than a dead, damaged, or disconnected battery.
Then is it possible you aren't seeing what you have described as "the failure" . . .
I raise this question as the wiring within the T@B is 100% the same for 12VDC power distribution from the Tow Vehicle or from the battery.
When on Tow Vehicle:
+12VDC comes in on the 7-Pin to the Junction Box +12VDC Terminal.
One of the wires at that terminal goes directly to the WFCO Power Center.
And then to the DC Fuse panel.
+12VDC path from the Junction Box to the Alde is the same.
And as you have noted, your T@B lights work on battery so the DC panel has voltage.
Edited to add @MuttonChops, great diagram. Thanks for posting.
I think this is what happened. First the battery was too low for the Alde screen to power on, but the other DC functions were okay. I checked the glass fuses on the Alde, and they were good. I connected the TV and was able to operate the Alde, and so I removed the trailer battery for charging with the Battery tender. When I disconnected the TV, I suspect there wasn't sufficient grounding without the battery connection. This blew one of the glass fuses. When I returned to test the charged battery, I was short on time and didn't test with the TV again or double check the glass fuses. Issue resolved. Always double check unbelievable results.
Thanks for the help!
