My truck purchased used did not come with a backup camera or the fancy in dash monitor. Is there such a thing as a truly "wireless" camera setup out there that just has the camera on a license plate holder and does not require hard wiring into the tail lights, and then has a monitor that plugs into the cigarette lighter inside the vehicle?
I know there are a lot of backup camera posts here, but I'm only finding ones that require hard wiring.
Thank you
2016 Nissan Frontier SV V6 4x4
Finally! New Owner of a 2017 Tab 320S!
Woohoo!
0 ·
I subsequently direct-wired the camera to the T@B wiring behind the Jensen speakers.
2021 Rav4 Prime
Woohoo!
2023 Ford Maverick XLT
The Finger Lakes of New York
Questions--I can just barely see the ball on my hitch even after adjusting the view by swiping up/down on the monitor screen. The camera rotation really doesn't do that much--it only "rotates left or right". Can either of you see part of your bumper or just see only the ball? Any more ways to adjust that view?
Do you worry about water getting in the camera if going through an automatic car wash? The instructions say water can get in if directly sprayed with water. I take my truck through the auto wash all the time.
Thanks!
Woohoo!
My camera does not view the ball at all so I have learned that when the bottom of the viewing frame lines up with the right position on the crank tower then my hitch is in the right place. Not perfect but close.
Sorry but have nothing to add on the car wash risk. I am trusting Costco will accept the return if my unit stops working under normal conditions (like car washes) - they have in the past, love that place.
T@B on!
2021 Rav4 Prime
Woohoo!
On another note, I had three cigarette-type, always hot connectors put in the back of my truck near the tailgate. The stupid trucks now days won't keep a hot connection (how is the compressor going to reach the camper wheels if they need air?). Keeping this in mind, can you find a place that'll put a hot wire to the back of your vehicle so you can wire a camera? Cap World did mine for a pretty cheap price (can't rem, that was 2018).
These are random, barely caffeinated thoughts that you may have already considered. Just ignore them if you've already considered such things!
Much luck to you in your quest!
Holland PA
2022 T@B 320S Boondock
TV: 2018 F150
Woohoo!
