As much as we LOVE our 2021 Tab400 that is now only a few months old, we’ve been unhappy about the fact that the exterior storage doesn’t lock. We noticed that the factory has added a lock on the 2022’s so we decided to figure it out.
Here is our m low cost solution. Home Depot sells basic cabinet key locks for about $6.00. It requires some handy skills and a few tools.
Here are the steps:
1- remove 1 latch. You need a Philips screwdriver
2- carefully enlarge the hole with a rat tail file making top and bottom the round parts. I used the metal ring that came with the lock as a template. I taped it over the hole with the prongs out. The amount of file work is minimal as the hole is 5/8 and the top and bottom need to be 3/4
3- install the lock with the supplied decorative washer and be careful not to over tighten the nut or the plastic may crack
4- use the offset lock bar from the kit as it is almost perfect
5- turn the remaining latch to lock then with the door open and up, use a ruler and using a sharpie, mark the offset bar at the same height as the factory latch
6- shorten the offset bar to the mark I used a belt sander and vice grips
7- assemble and test the lock fit
cheere
we specifically chose not to make a round hole. The barrel of the lock has flats to prevent it from rotating, so the hole is actually an oval. It turns out that the existing hole is almost exactly the size required for the flats, so we only filed the top and bottom
good point and this is something that we thought about. I’m not sure if exterior grade locks of this style are available. Our plan is to lube it with WD40 as a preventative
Oh! I will mention that to hubby. I think we have some of that it n the basement.
We already have some wd40 in the door lock. It seized on us a couple days after delivery abd we live a long ways from a dealer. So we used WD40 on the fly at the time.
Is it ok to apply the graphite after WD40 is already in there?
we just returned from a 12 day, 2500 mile voyage round trip from NY to KS. Close to getting home, I noticed the screw keeping the lock in place has loosened from the vibration.
Thanks
2021 Ford F150 2.7 turbo
