I've seen postings of people repacking bearings and adjusting torque. One of the manuals advises to adjust the electronic brakes on the T@B. I admit, I haven't done anything except dewinterize, winterize, and tow it.
Has someone developed or found a maintenance checklist, based upon mileage, similar to what you would find in a TV manual? I now have between 2500 and 3000 miles on the T@B and am thinking I should be doing something (besides getting those washers for the clamshell - hee hee). Thanks!
Beth
Minnesota
Practicing to be a wanderer
Transitioned from 2014
T@B 320 CSS
M@xx to 2020 T@B 320 CSS Boondock Lite
2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
0 ·
Yup, we need a list. I had the wheel bearings repacked and greased as close to 6,000 miles as I could on my Silver Shadow. When I stopped for a break, or at the end of a long downhill, I checked the center of the wheels for heat (never did get hot). I checked the air pressure in the tires. But, now I realize I'm not sure about the wheel bearing maintenance on my 2014 T@B. I did find out I just have to check they hydraulic fluid on the surge brakes every once in a while.
If you don't have a maintenance free battery, you do need to check the level in the battery. Only use distilled water.
From reading here, you need to check the level of the glycol for the Alde. Only fill with distilled water or the specific glycol mixture (do a search, Normfun found the correct brand at O'Reilly Auto Parts).
Check for tire wear. It sure looks easier to see than on my Silver Shadow with those beautiful flared fiberglass fenders!
Check to make sure your spare tire is still tight, no matter where you store it.
Next.....
And obviously systems like the Alde system and water holding tanks require winterizing, etc. I am looking at my trailer constantly and do perform maintenance (lubrication) on the stabilizers, trailer tongue, hinges, etc. And depending where I am staying or store my unit I'm looking for insects like ants as I've always had quite the time with this down in Florida where I store the trailer while staying in a condo, etc.
Another thing I do is protect my trailer against rust and inspect the under side of the trailer because this area is exposed to the road and is virtually sand blasted and pelted with rocks and any road debris you encounter during your travels. A wire brush helps, as does a can of black spray paint to protect and preserve the metal frame.
Proper tire inflation is important too prior to travel and applying grease to the hitch ball and lubricating the tongue hitch's moving parts is essential whether prior to a trip or maintaining these parts when parked.
Inspect the caulk along the seams of the trailer along the walls and replace if necessary.
Another important point (as I know that others will add to this list) to keep in mind should you take your trailer in for either new tires or axle bearing maintenance is to make sure that whomever works on your trailer DOES NOT put a hydraulic jack under the trailer axle and use the axle to lift the trailer up. I had a guy at a local tire store recently try to do just that. I stopped the mechanic and told him that this is a no-no and the axle manufacturers do not approve of this as it could damage the axle. I also spoke to the store manager and he said it was good to know, but no one had ever told them about this.
There are other things to consider or do but inspecting your trailer's safety chains and wiring harness is another thing to look at. The metal tag on the safety chains can be removed as it is from the chain manufacturer, but isn't needed. Look for chain wear, check the hook attachments and check the harness for any scuffs or potential damage from pinches or abrasion.
Hope that helps some and I'm sure others will add to the list.
Minnesota
Transitioned from 2014 T@B 320 CSS M@xx to 2020 T@B 320 CSS Boondock Lite
Inquiring minds are wondering!
/gets out google maps and a calendar to figure out trips since purchase in May....
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
I have had boat trailer bearings fail, after the trailer has sat for the winter, during first use in the spring. Now, I repack (or have repacked) my trailer bearings and brakes inspected the start of each season.
Dexter also recommends inspecting brakes every 3 months/3K miles of use. This is not a bad idea, better to stay ahead of any potential issues, rather than have a failure on the road.
