Anyone have their floor repaired after a rear leak?  If so, how is the repair performed?  I have staining and some soft wood on each side of the trailer - the drivers side is worse than the passenger side.  I assume it is from a taillight leak or a leak at the wheel well.
                Kathy
2018 T@B 320S - Cl@ra
0 ·
Once we had the leaks repaired, and the wood dried, we simply left it in place. Your 2018 has no wood in the walls, floor or roof front to back. There are only wooden cabinets, window soffits/facia and the cosmetic piece in the back under the taillights. If you are referring to the angled cosmetic piece, anyone who can cut plywood can make a replacement piece for appearance sake. Is this what you are referring to? My pics look like this:
Driver's side
Passenger side.
This is located under the back lower cabinets, behind the sofa bench.
I realize you have a clamshell, and your behind the sofa piece may be vertical, and more a part of the cabinet area. If so, you may need someone more skilled in wood replacement or repair. I am not able to assist with that, but I was hoping you don't actually have a soft floor or other complications.
P.S. nüCamp performed the taillight leak repair. They did not deem it necessary to replace the stained area as it is still solid, and we didn't ask or demand anything else be done. This was a warranty repair performed at üCamp17. And my taillights have never leaked again. Good luck. -Denise
That will be true especially if the stains are in a covered area and are not structural in any way, and fortunately, for both of us, they are not. Again, good luck with this. Btw, I can see my photos as well as yours and I am on a mobile device. Hope you at least get a peek at mine.
There are wood beams inside that plastic wrap, which joins that angled back wall to the floor..
So, yes, there is wood behind the plastic, only at the front & rear ends of the floor.
I may be a bit disoriented, but it looks like where you made the slit to drain water is on the floor side of that joint, forward of the wood beam? Based on that, it seems more likely that the water may have come from a leaky wheel well seam. On the other hand, that angled wood back is water stained, which seems to be more indicative of a taillight leak. My recent glycol leak onto that angled board ended up draining right through the seam rather quickly after I added more, though I'm now wondering if there may still be some residual glycol inside of the floor.
I think I will try tilting our trailer nose-up and see if anything more drains from that rear seam. I don't want to cut that water barrier just to see if there is anything inside.
Let us know what you find at your wheel well caulking joints or taillights.
Apparently, the factory did not properly seal this seam and the basic design facilitates water entering the trailer. The roof should have overlapped the plastic tail section to prevent water entering.
