Bayliss
Member Posts: 1,493
QUESTION: For those who have added external fans to your 3-way refrigerator, can you tell me if that has helped maintain the refrigerator temperature while operating it on battery only, while towing? I am also interested in forum member thoughts on the pros and cons of switching out my 3-way refrigerator for a more efficient 2-way model, for the reason described below.
I have the originally installed 3-way refrigerator (Norcold N180.3x) in my 2019 320 S Boondock Lite. Unlike many other T@B owners, I have had no operating issues with it, EXCEPT I have experienced the often-reported problem of it struggling to maintain the proper temperature when the ambient/outside temperature is in the 90s+. Therefore, in conjunction with installing a lithium or AGM battery, I am considering either adding dual external fans, OR swapping out my 3-way refrigerator for a 2-way model.
I do not want to operate the refrigerator on propane while towing. I have operated it on battery (Group 24, lead acid) while towing with my truck, which has a 150-amp alternator that keeps the trailer battery properly charged. However, even if I start out with a very cold refrigerator, the battery does not help the refrigerator maintain a sufficiently cold temperature while towing in hotter outside temperatures (i.e., the temperature rises significantly.)
I currently intend to upgrade to either a 100 Ah (minimum) lithium, or a 125 Ah AGM battery. Since I am not having any problems with the 3-way (other than as already described), I am wondering if adding a couple external fans will likely solve the temperature issue (both while camping and towing.) If so, I don’t feel the urgent need to switch to a 2-way model, particularly since my 3-way is essentially in brand new condition. Greg)
Now when running on gas or 120V at a campsite, additional fans do help with removing heat from the fridge compartment.
"Just Enough"
“The ammonia refrigeration cooling system which is also known as an absorption cooling system was first discovered in 1824 by Micheal Faraday who tried to liquefy gases which, among them was an ammonia gas. This experiment was used in taking ammonia vapor in a glass tube with silver chloride in it and allowing it to absorb in the silver chloride powder. He then heated the chloride -ammonia mixture and watched the ammonia liquid evaporate out of the silver chloride and become cold. This experiment later was the birth of the ammonia absorption cooling systems [HEREAFTER CALLED PROPANE REFRIGERATORS].
“In 1926 Albert Einstein and a former student, Leo Szilard, embarked on a venture to develop a safer refrigerator since the electric refrigerators of the time were known to leak toxic gases through broken seals. Such an incident of a German family killed by fumes caught the attention of Einstein and sparked this project. Einstein insisted that a better refrigerator design must be possible.
“Their goal was to design a device with no moving parts or mechanical motion and eliminate the wear and tear factor. They used their knowledge of thermodynamics to produce an absorption refrigerator. This device would drive a combination of safer gases and liquids through three interconnected circuits. It required only a small gas flame as a heat source and was totally sealed and safe. Some experts estimate the sealed system could last 100 years.
“Einstein and Szilard applied for and received 45 patents in 6 countries for this type of refrigeration technology.”
If is stays below 85 they work great without any electricity. Stuffing the top of the propane frig with ice will help in areas that are hot during the day and cool down at night. July and August in Arizona is tough for that design, but workable.
That being said, I like my compressor frig. Texas doesn't cool down at night and AC becomes a necessary for about 5 months. So, I'm not trying to operate on batteries.
"Just Enough"
