Need to replace 2004 T@B Converter
breon2013
Member Posts: 6
The American Enterprise Converter in our 2004 T@B bite the dusk and needs to be replaced. Does anyone know where one can find a Model CS2000XL? Or baring that, what would you suggest as a replacement? TIA.
I would consider getting the new Waco converter currently being used by nüCamp,on their 2022 model, it has a lithium battery setting should you decide to upgrade the battery to a lithium ion battery.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
Thanks. I'll give that some thought.
@breon2013 - how do you use your TaB? Full hook ups all the time with infrequent spells of dry camping? What kind of battery do you have? Any plans to change battery type? You have other options for converters.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Here is how I put a new converter in my 2007.
See attached file
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL -
Mouse-ke - Thanks I will refer to your file again if I go with a different converter. (which looks is a strong possibility)
Sharon is SAM - We usually use a full hook-up and plan on continuing to use a lead acid battery.
@breon2013 - well, that should be easy then. Check this out from etrailer: https://www.etrailer.com/question-518800.htmlSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Sharon - Thanks for the lead. Really appreciate the help.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
