Cigarette Outlet Fusing
AnOldUR
AnOldUR Member Posts: 1,757
Our 2020 320S has a cigarette lighter type outlet in the back by the bed on the drivers side. While trying to find out what each of the 12V fuses provided protection for, I removed every fuse. None of the fuses cut power to that 12V cigarette outlet. Anyone know why or have an explanation?
edit to add: To see if there was power there, I plugged in a 12V device that had an LED pilot light on the plug. That light never went out. Could there be residual power keeping the light on even after the fuse is removed?
  • Freespirit
    Freespirit Member Posts: 187
    @AnOldUR there is a response from @Bayliss that solved my issue that appears to be what you are describing. His response is at the bottom of the discussion titled
    Fuse keeps burning out
    2020 TAB 320 U
    TV 2025 Telluride X Type
    MuttonChops Member Posts: 2,058
    @AnOldUR the referenced thread @Freespirit provided is a bit long.
    The short version (pulled from the 'Fuse keeps burning out' thread) is your LED Pilot light is 'seeing' the available current used to light the Power Center 'Fuse Bad' LED.
  • AnOldUR
    Thanks. Sounds similar to the household wall switches that glow when in the off position so that you can find them in the dark. So any load greater than a little led would not pass through the resistor? Makes sense. I'll give it a test under load to confirm it in my head.
  • JeffroNC
    JeffroNC Member Posts: 366
    @AnOldUR that’s why I keep an old school incandescent 12v test light. It won’t glow on a high resistance circuit like the one above. It also provides a small load which helps me with diagnosis.
    Jeff & Amy
    Now in Manistee, MI
  • BrianZ
    BrianZ Member Posts: 1,770
    edited December 2021
    Not exactly, but, without the fuse in the circuit, the available current is limited by the circuit to something on the order of 10-15 milliamps.  That's enough current to light an LED.
