Cigarette Outlet Fusing
AnOldUR
Member Posts: 1,759
Our 2020 320S has a cigarette lighter type outlet in the back by the bed on the drivers side. While trying to find out what each of the 12V fuses provided protection for, I removed every fuse. None of the fuses cut power to that 12V cigarette outlet. Anyone know why or have an explanation?
edit to add: To see if there was power there, I plugged in a 12V device that had an LED pilot light on the plug. That light never went out. Could there be residual power keeping the light on even after the fuse is removed?
@AnOldUR the referenced thread @Freespirit provided is a bit long.
The short version (pulled from the 'Fuse keeps burning out' thread) is your LED Pilot light is 'seeing' the available current used to light the Power Center 'Fuse Bad' LED.
Adventures: 61 Nights: 417 Towing Miles 51,0502 -
Thanks. Sounds similar to the household wall switches that glow when in the off position so that you can find them in the dark. So any load greater than a little led would not pass through the resistor? Makes sense. I'll give it a test under load to confirm it in my head.
Not exactly, but, without the fuse in the circuit, the available current is limited by the circuit to something on the order of 10-15 milliamps. That's enough current to light an LED.AnOldUR said:So any load greater than a little led would not pass through the resistor?
-Brian in Chester, Virginia
RV: 2018 T@B 320S, >100 mods1
