No. The blue light can be used as a night light but can be turned off.webers3 said:Looks great, is the blue light always on?
guy, but I do think that the switches symmetrically tilted toward the center looks fine.
What type of meter would I use and how would I go about testing the parasitic draw of a USB port?AnOldUR said:After reading @YanniLazarus post, I realized that my edit above may be misleading. That measurement was taken from a 5V USB port that I installed below the reading light on the passenger side by tapping into the lights 12V feed. The factory installed 12V cigarette lighter and 5V USB port on the drivers side are fed by a different fuse/circuit. There's a small LED pilot light on that USB port, but the draw is too small to register on my meter. I got the same results there, zero amps drawn with nothing plugged in.
Those of us with the "blue light special" would love to hear your test results!elbolillo said:What type of meter would I use and how would I go about testing the parasitic draw of a USB port?AnOldUR said:After reading @YanniLazarus post, I realized that my edit above may be misleading. That measurement was taken from a 5V USB port that I installed below the reading light on the passenger side by tapping into the lights 12V feed. The factory installed 12V cigarette lighter and 5V USB port on the drivers side are fed by a different fuse/circuit. There's a small LED pilot light on that USB port, but the draw is too small to register on my meter. I got the same results there, zero amps drawn with nothing plugged in.
AnOldUR said:I believe that a USB port installed by the reading light would convert 12V to 5V. Would there be any draw if there was no load?edit:
Went out and did a test. With nothing plugged into the USB there was no draw through the fuse feeding it. When I plugged my phone into the USB it read about a .4 amp draw. This would lead me to say that there is no phantom draw from the USB port. Note that my cheap meter only reads one digit past the decimal point and rounds off the reading. It's possible there could be a draw of less than .05 amps.
