Power tongue Jack cost less than a buck
Dalehelman
edited July 2015 in Tips & Tricks
If you use a cordless drill for your stabilizers check this out, and it will not drain your house battery.
  1. Hash  T@B Fun
«13
  • JandJ92010
    JandJ92010 Member Posts: 304
    THAT is an AWESOME idea! Well, now I know what I will be doing tomorrow, I have an electric jack, but it won't fit with the tongue box that I have. This is the answer. Thank You!!
  • Rad
    Rad Member Posts: 516
    Ok, please don't take this the wrong way......The idea is clever; however when did we lose the ability to turn a crank by hand?
  • jkjenn
    jkjenn Member Posts: 6,425
    Wouldn't it take longer to take the cover off of the top of the jack than to it would to use the hand crank?
  • Rad
    When we turn 63.
    I passed that milestone.  I can still turn a crank, as long as I don't have to use my back.  Just got a set of steroid injections in L5 on Friday as I'm hoping to hold off a second back surgery.
    This whole getting old thing is not for the timid.   :o
  • Dalehelman
    At 69 I save my energy for more important activities.
    1. Hash  T@B Fun
  • Sgtjohn
    Sgtjohn Member Posts: 238
    When we turn 63.
    And when we've had a total shoulder replacement on one shoulder and we have to baby the other shoulder lest we have a replacement on that side too.
    (It's just part of hanging around so long).
  • JandJ92010
    I say let the battery drill do the work, it's running my stabilizers up & down anyway.
  • Dalehelman
    Jand: makes since to me.
    1. Hash  T@B Fun
  • Sgtjohn
    The idea-I think is to modify the crank so that the cap remains on (which will keep the gears clean) and to set aside the hand crank for emergency use.  Is that it?
  • Dalehelman
    edited July 2015
    sgtjohn: That's correct. I welded a 3/4" socket to the crank. You can also use a 3/4" socket and ratchet or a 3/4" wrench.
    1. Hash  T@B Fun
  • Sgtjohn
    That is a great idea, having a backup in case the drill battery runs down!
  • JandJ92010
    Oh yeah, gotta have a plan "B".
  • Allie
    Allie Member Posts: 194
    Pictures are great, and give the general idea, but have a few questions about details please.  What size bolt did you use to replace the crank?  Did you have to drill a hole in the bolt?  What does the bolt attach to (opposite side of bolt head)?
    Allie
    Condo A-Go-Go
    2017 Tacoma (AH GOGO)
    S. UTAH
  • Dalehelman
    1/2" bolt use the crank to determine length and where to drill hole. Use hammer to drive roll pin behind gear out. The roll pin is the only thing that keeps  things together.
    1. Hash  T@B Fun
  • Dalehelman
    Allie: Once you pop the top cover off and wipe off some of the grease it should make more since.
    1. Hash  T@B Fun
  • Allie
    Dale, thanks.  I'll have to take a look see before I take everything apart and screw it all up.
    Allie
    Condo A-Go-Go
    S. UTAH
  • Mercator
    Mercator Member Posts: 237
    Here is another similar solution, but using the levelling jack handle as a reserve. http://www.funfinderclub.com/phpBB2/viewtopic.php?t=1738
    Ray and Vida Barrick
    (formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
    Toronto ON Canada
  • vito
    vito Member Posts: 181
    What would an electric jack cost commercially? Some of us are not skilled in welding, etc. Just curious.
    2016 T@b S Maxx
    2011 Subaru Outback
    Rockford, Illinois
  • Dalehelman
    No welding is needed drill 1hole then saw off the excess. Power jacks run $125 and up plus install and wiring. They will also draw considerable power from your battery.
    1. Hash  T@B Fun
  • ericnliz
    ericnliz Member Posts: 4,437
    edited May 2017
    @Dalehelman, Thanks for the bolt! :) Gonna save my back & I'm with you, save my well-seasoned body energy for more fun things! =)
  • Estancio
    Estancio Member Posts: 243
    Great tip! Thanks for the clear pictures.
    Stancil Campbell
    2011 T@B
    Rockingham, NC
  • Dalehelman
    The hole is 5/32" and it is necessary that it is centered.
    1. Hash  T@B Fun
  • db_cooper
    db_cooper Member Posts: 749
    Love this mod. Assuming you have a drill press for making the hole?
  • Tabaz
    Tabaz Member Posts: 2,420
    After living with this mod for over a year, it still brings a smile to my face each time I hitch and un-hitch the T@B.  Thanks Dale!
  • Dalehelman
    It can be done with a hand drill. It just may take more than 1 attempt to get it right. Give it a try. Good luck
    1. Hash  T@B Fun
  • drpprmt
    drpprmt Member Posts: 117
    shucks,  I have 10yrs on you and I can watch my wife turn that crank all day long.  Looks like a good mod though
  • BrianZ
    BrianZ Member Posts: 1,770
    edited June 2018
    In recent years, I have only used a corded drill, but can anyone recommend a good cordless drill for this purpose.  I gave up on them many years ago, as batteries & chargers never seemed to last, though it may have been a cheap one and now they have lithium batteries.  I can't see using an extension cord for this, but I'd be willing to buy a cordless drill to keep in the trailer.
  • Verna
    Verna Member Posts: 6,876
    I love my 20V Lithium DeWalt drill and driver set, but I use them a lot so I can justify the cost.  It’s amazing how long the charges last with lithium batteries. The same 5AH batteries fit my Jigsaw, string trimmer, hedge trimmer, leaf blower, and my next purchase of a circular saw.
    I used a nice Mikita the other day evening, and I think it was a lithium powered drill also. I have no idea how much it cost.
    Be sure to get a Lithium battery operated drill, with at least two batteries. The charge lasts “forever” and gives you no warning it is dead and needs recharged—it just stops. The charger can also be used on an inverter if you are camping without electricity.
