Hi everyone! I am a new owner of a 2022 Tab 400 Boondock. I am trying to put together e budget for maintenance. We have a decent estimate number of miles well travel (~2000/year) and we’re trying to convert that into a monthly line item. Does anyone have reliable numbers on yearly expenses?
0 ·
We have a 2020 400 BDL and have put right at 11,000 miles on it in nearly 2 years, I have done all of the maintenance.
My estimate for supplies that I have purchased including anti-freeze for winterization is $25.00.
I need to change the glycol for the Alde this spring, so that will be another $250.00 for materials to do the job including the glycol. There have been posts where people have paid up to $750.00 for this work.
If you put $25 to $50 per month to the side, you will be fine, even if you need to pay someone to do these things for you.
Brad
P.S. You will likely spend way more on your tow vehicle for additional maintenance than the 400.
Concord, NC
3. Annual winter lay up, draining water system, adding RV antifreeze.
4. Bi-annual replacement of glycol in Alde system (this is the most expensive maintenance item, cost is $250-400 depending on the dealer shop rate. You will already have the new glycol, so only need to do a drain/pump out old glycol and pump in new glycol. With the new dual drain/inlet setup on the Alde, this is best done by a TaB (nuCamp) dealer or an Airstream/Alde service center.
5. Every three to five years, depending on unit of use, replace tires, which suffer from side rot even if low mileage on tread. (Edit: Added to complete list)
St Catharines, ON
Wheel hub annual service is around $200 if you have a shop do the work, probably around $50 if you do the work. It is recommended every 12k miles OR annually regardless, so even low yearly miles requires this expense.
Alde service as mentioned is another larger expense, again variable costs depending on labor.
All in, I would say around $50 a month would be a good budget number to cover maintenance. Of course as unit ages there will be other stuff pop up.
2017 F-150
Coeur d'Alene, Idaho
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
