Where do you store your sewer hose?
I bought one of those collapsible sewer hoses at my RV dealer's store, and right now I have keeping it in the compartment with the battery and the propane tank. Since it hasn't yet been used its totally clean and dry, but once I use it (hopefully in the next few days) I am trying to think of a good place for it. There's really no room in the T@b for it, and I am not sure I want to keep the hose (after using it to empty both the gray and black water tanks) in my TV. I guess I could put it in a heavy plastic bag and put it in the TV, but the list of things to keep in the TV seems to be getting longer and longer. What do experienced T@b owners do?
2016 T@b S Maxx
2011 Subaru Outback
Rockford, Illinois
«13
  • Orygun
    Orygun Member Posts: 17
    Since my TV is a truck, I throw it in the back in a plastic box. It's also really not that bad smelling, since I always rinse out the tank and hose at the dump station before I leave.
  • Cyclonic
    Cyclonic Member Posts: 1,232
    Mine goes into a homer bucket and into the TV.
    Sterling, VA
  • Nomad
    Nomad Member Posts: 7,209
    edited July 2015
    Coiled up in the propane cover - Rinse out good and cap the one end. - The pvc tube in there is designed to fit the dump end of the hose.
  • jdargis
    jdargis Member Posts: 305
    Mounted a plastic Stanley tool box between jack stand and propane cover on trailer tongue.  Silver and black in color, so it blends in with our silver T@B.  Drilled 8 holes in bottom of box, secured with 4 u shaped clamps around trailer frame, secured by fibre nuts in the bottom of the box.  Over 10,000 miles on the trailer and no problems, also the sewer hoses are located right where I using them.
    Also, I have the T@B bike rack, so storing them in the propane cover is not feasible.  The negative is, I can not mount the spare tire up front on the tongue.  But the weight of the bike rack and bicycles and putting the spare tire up front would push the tongue limits of my vehicle.
    So I prefer to have the hoses there, the low spare tire in back has not been a problem for us.  Plus, changing the tire is cup of tea, compared to repairing a flat on a motorcycle on a trip.
  • Nomad
    Wasn't screwing ends together about "water" hoses?
    My Rhino ends won't attach to each other.
  • twocutes
    twocutes Member Posts: 202
    I store similarly to PXLated.  It's not ideal, but best solution for the moment.  I plan to install a tongue box, but would like to use that for less dirty items.
    Beth
    Minnesota
    Practicing to be a wanderer
    2020 T@B 320 CSS Boondock Lite
    2014 T@B 320 CSS M@xx
    2020 Jeep Wrangler Unlimited 8 speed automatic
    2020 Jeep Grand Cherokee Limited V8
    2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
  • jdargis
    You can buy male and female sewer caps through Camping World. Can not hook the ends together, but put one end on, squeeze hose down in length and put other end on,
  • jkjenn
    jkjenn Member Posts: 6,424
    Patti said:
    I guess I need to go look and see what kind I have because the ends do screw together.
    A picture's worth a thousand words.
  • Mouseketab
    Mouseketab Member Posts: 1,262
    I mounted a PVC tube on my tongue behind the propane tank. (I don't have a plastic box on the tongue.)
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • JiroTX
    JiroTX Member Posts: 124
    I have mounted some plastic boxes on the Outback front platform and put my sewer/water hose separate in those boxes.
  • BWidget
    BWidget Member Posts: 35
    I'm still experimenting. Right now they are in the bin on the left.
    Bill from Los Angeles Arizona
    2015 T@B S Maxx Outback
    2020 Jeep Grand Cherokee Trailhawk
  • Kats
    Kats Member Posts: 95
    We used to just stow our hoses in the propane tank cover. But we took a trip recently and hit more than a few bumps on the roads leaving the Berkshires. On the Taconic State Parkway several people came up next to us and drove alongside looking at us. We thought they were just looking at the T@B, which happens a lot. No, it turned out they were trying to get our attention to tell us that half our sewer hose was dragging on the pavement under the trailer. The pavement beat the...stuffing out of it. Now we have it secured with clothesline to the inside of the propane tank cover.
  • twocutes
    Nice photos of Outback storage.  Wish I had me that platform/rack on either side of the propane/battery compartment.
    Beth
    Minnesota
  • vito
    vito Member Posts: 181
    Is that platform under the propane/battery box available for other than the Outback model?
    2016 T@b S Maxx
    2011 Subaru Outback
    Rockford, Illinois
  • jkjenn
    Ummmm,,, you do realize it's illegal to drive with a trailer on the Taconic, right?
  • JustJohn
    JustJohn Member Posts: 171
    I ordered my Sofitel with the diamond plate box and Outback platform, wheels and axle. You can order the platform from LG separately, so the answer is yes. Expect to wait a while if you custom order, mine is scheduled for Sept. 9 and was ordered in June.
  • bgualtieri
    bgualtieri Member Posts: 272
    edited July 2015
    We got a piece of ½" wire mesh -- the kind of fencing you'd put around a garden to keep the rabbits out -- made a tagboard template of the curve of the propane/battery box, cut the wire fencing to shape with snips, inserted it from underneath, and wired it to the framing. The front curve sits over the front lip of the plastic propane/battery box. It wouldn't hold any weight as a "floor" but it's enough to keep the sewer hoses inside.
    2015 T@b S Max | 2015 Jeep Wrangler Unlimited | was PHX East Valley, now Dallas!
  • Mercator
    Mercator Member Posts: 237
    I use a Valterra E-Z Hose Carrier that is fastened to the side of the tongue.  It has a cap on each end for easy cleaning and holds a length of sewer hose easily.  The extra fittings (right angle, etc.) go into a small rubbermaid type box.
    Ray and Vida Barrick
    (formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
    Toronto ON Canada
  • Ratkity
    Ratkity Member Posts: 3,770
    edited August 2015
  • Mercator
    edited July 2015
    Parkways are usually limited-access roads normally prohibiting commercial trucks and semi's. This one is one of the longest in the U.S. (if not the longest).
    Since there are many jurisdictions, there's probably several caveats to the trailer rule, but from the NYSDOT website:
    "The following type vehicles are not permitted on the Parkways within the Parkway system, unless authorized under an agreement with the New York State Department of Transportation:
    (f) house coaches;
    I wonder how they define trucks? Does that include SUVs? The website was titled "New York State Parkways and Commercial Vehicles". Does that list mean all those things used for commercial purposes?
    As per all gov't websites, details were vague. YMMV. Class A's and Semi's use specific GPS systems that avoid roads where they are prohibited and/or there are size/height restrictions.
    Edited to add apologies for thread hijack!! Eep. Need more coffee.
    Is a T@B considered a "house coach" in the list?
    Toronto ON Canada
  • Allie
    Allie Member Posts: 194
    Does the platform make it difficult to dump the holding tanks?
    Allie
    Condo A-Go-Go
    2017 Tacoma (AH GOGO)
    S. UTAH
  • twocutes
    Mercator - Could you share a photo or two of Valterra EZ hose carrier mounted?
    Beth
    Minnesota
  • Nomad
    Katz - Ball Bungies - I secure mine to the propane tank with a small ball bungie. Hasn't come dislodged in 12,000 miles including rough back roads boondocking.
  • jkjenn
    (f) house coaches;
    Is a T@B considered a "house cache" in the list?
    It's considered a trailer.
  • Mercator
    edited July 2015
    Installed on the passenger side along the side of the tongue, sloped slightly towards the rear for drainage when the hose is stowed.
    The 2013 T@B has surge brakes, so the hitch might look different to the newer models.  I don't know whether that would make it easier (or harder) to install.
    Toronto ON Canada
  • jcfaber1
    jcfaber1 Member Posts: 318
    I too use the valterra 64 inch pvc carrier.  Mine is mounted underneath to the aluminum frame I made which holds our water tank.  Our t@b is a 2007 Dutchman.
    2007 T@B
    Rockford, IL
  • jebelhafit
    jebelhafit Member Posts: 17
    I have a Rhino drain hose stored in the propane/battery compartment.  I added a larger diameter white drain pipe in two pieces to allow for easy removal of the battery cover.  One end goes in the drain pipe provided and the other in the newly installed pipes.  Seems to work quite well.
  • Rad
    Rad Member Posts: 516
    Broken record here, my waste hoses don't touch or lay against anything that I may later hold or handle without latex gloves on.  That includes battery boxes, propane tanks etc.  Mine lives in its own bin in the back of my truck.
    I do really like that set up with the bin on the outback front rack.  I would drill a series of ventilation holes in the bin.
  • Nomad
    edited July 2015
    I rinse mine really well inside/out and cap the end - only the outside is ever in contact with anything like the battery box. Periodically I wash/rinse out the interior of the cover including the battery box. And wash my hands good after.
    I've handled far worse in my life - and before they invented latex :-)
  • jdargis
    No one with the platform has answered the question on hooking your sewer hoses and dumping, I have not seen an Outback model and if there are no extensions, this could be one interesting situation if there is a hose problem.
