2004 Dutchman TaB - Asking about a pump system.
Firsttimers
Member Posts: 7
Does anyone know what I need to get for the sink system? I have a sink and faucet but no pump or fresh water tank. It all drains on the ground along with the ice box in my 2004 tab. I don't have a manual for this tab and we are first time camper owners. Just looking for answers.
@Firsttimers, you have a Dutchman t@b. Look at the categories on the left hand side of the page. There is a Dutchman archive category and that will get you started. Then there are resident experts here who will certainly chime in to help you. When your camper was designed and manufactured, the laws were different and in many places you didn't have to retain your gray water for proper disposal. Sounds like you may have to do some retrofitting to make your camper fit your needs. But that is some of the joy owning one of these campers, making it your own. Happy t@bbing to ya!2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus. -
Thank you dragonsdofly for your help.
The Dutchman TaBs used a portable tank to collect the gray water. The sink faucet water was from a simple in-line pump connected between the faucet and a large (5-gallon) water bottle under the sink, which was the fresh water supply.
Welcome aboard, happy camping and stay safe.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
@Firsttimers, The '04 DM T@B's came with a 5gal. portable freshwater tank, inline 12VDC demand pump, and the drain was just on the ground. A previous owner may have had a pump failure and just decided to take out the pump and tank (as I did). I installed a hose connected water inlet (no freshwater storage), and a portable grey water tank connected to the drain outlet with a short hose.
https://www.walmart.com/ip/Tote-N-Stor-25951-6-Gallon-Portable-RV-Sewage-Waste-Water-Tank-Tote-Carrier/159406496?wmlspartner=wlpa&selectedSellerId=1
Geo & Liz
T@BMahal
'04 #100 -
@Firsttimers - there is a good 6 gallon waste tank being offered for the cost of shipping. It could be yours! https://tab-rv.vanillacommunity.com/discussion/14580/6g-waste-tank-give-away-plus-shipping-cost#latest
Thank you to everyone that gave us info on our 2004 water system. It is so appreciated.
Hello @Firsttimers If you haven’t received an answer on the pump, this one will fit: Shurflo model 105-003. It is a 1.0 GPM 12v 30 PSI pump that is either or equal to OEM. I recently replaced mine on a 2004.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
