Just traded in my Class A for a new 400 Boondock and some cash! Only had it a couple of days but loving the space we have got back on the driveway and have started to de-clutter and sort through all the stuff we used to take with us. Would appreciate any advice re heating tips using the Aldi system when dry camping and do you heat it at all when parked on the driveway (in the winter) and connected to shore power?
If you're in Canada (Vancouver) and want to meet up to discuss tips over a coffee/tea PM me.
2022 400 Boondock + Disco 5 Diesel
2 ·
Make sure your battery is charged and the switch is "on"
Make sure you have propane and open the valve slowly
Fill the propane line by lighting the stove briefly, with ventilation in the cabin
Ensure the Alde reservoir has glycol to the proper level. Location varies by year.
You should be winterized so the water heater should be empty. That is OK
Go to the Alde control and turn it on. Green LED should be on and then press the Menu screen to bring up the settings for heat and hot water. You should see icons for Thermostat at top then hot water (this should be off) and the the electric heating icon, which should also be turned down/off.
The bottom control icon is a flame which is propane heat. Turn that on and the thermostat should start the fan and then you can hear the burner kick in. It is pretty quiet but you can hear it. Go outside and ensure the exhaust is coming out and then wait for the convection to warm the cabin.
Lots more on this in the forum and the dealer may have provided the 3020 manual as well it will tell you more.
In the image below the control is set at 72 deg and the hot water at normal (partially filled). You would hit the Minus to clear that ramp in your case.
Then the electric is set to 2KW and you would hit the Minus to clear that to Off as well.
The bottom icon will turn green when ON and that should get it going.
Good luck
PS as far as heating on electric in driveway it would depend on your humidity in the cabin. Where I live and with my storage it is not needed. I hear others use a small portable heater or dehumdifier for longer storage
Amen on getting rid of stuff! I got too much stuff when we started camping. It’s amazing how much of it we have voted off the island.
Our Tab has frozen hard in the winter and we have not had any issues. When I run the heat there is condensation. I usually have the kitchen window open to the second catch on the levers and the bathroom vent open. I use a chunk of pool noodle to prop the bathroom door open. We have been in driving rain and wind like that with no water intrusion. Enjoy!
Jeff & Amy
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
