Battery Install
Kevin_Campbell
Member Posts: 4
Can anyone tell me where the disconnected cable (with 30 amp fuse goes in this picture)
positive or negative post ? Thank you in advance for any help.... 2017 T@B CSS
Positive. I'm positive. ;-)2015 T@B Max S (320)
Thank you ScottG !!!
@Kevin_Campbell Is that a negative symbol I see on the case next to the post on the side where the red wire is connected?-Brian in Chester, Virginia
That does indeed look like a negative symbol! I just looked at three deep cycle lead acid batteries that I have in the garage and they all have the negative terminal on the right side of the battery if you look at it the way it is in the picture. I would definitely trace the wires and see where they come from before I would proceed.2021 320S BD
2017 F-150
Coeur d'Alene, Idaho -
My 2017 original battery.
Towed by 2014 Touareg TDi -
@pthomas745 if you ignore the orientation of the label and look at the location of the round posts @WayneW is still correct. Some car batteries have the terminals switched (often indicated by an "R" suffix) but I've never seen that on RV deep cycle style batteries.
going to check it now thx guys
think this looks better.... boy tracing those wires back is a chore... Thank you all for your help
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
