Battery Install
Can anyone tell me where the disconnected cable (with 30 amp fuse goes in this picture)
positive or negative post ?   Thank you in advance for any help.... 2017 T@B CSS
    Positive. I'm positive. ;-)
  • Kevin_Campbell
    Kevin_Campbell Member Posts: 4
    Thank you ScottG !!!
  • BrianZ
    BrianZ Member Posts: 1,770
    edited February 2022
    @Kevin_Campbell Is that a negative symbol I see on the case next to the post on the side where the red wire is connected?
    -Brian in Chester, Virginia
    RV: 2018 T@B 320S, >100 mods
  • WayneW
    WayneW Member Posts: 261
    That does indeed look like a negative symbol! I just looked at three deep cycle lead acid batteries that I have in the garage and they all have the negative terminal on the right side of the battery if you look at it the way it is in the picture.  I would definitely trace the wires and see where they come from before I would proceed.
    2021 320S BD
    2017 F-150
    Coeur d'Alene, Idaho
    My 2017 original battery.
  • Grumpy_G
    Grumpy_G Member Posts: 788
    @pthomas745 if you ignore the orientation of the label and look at the location of the round posts @WayneW is still correct. Some car batteries have the terminals switched (often indicated by an "R" suffix) but I've never seen that on RV deep cycle style batteries.
  • Kevin_Campbell
    going to check it now thx guys
  • Kevin_Campbell
    think this looks better.... boy tracing those wires back is a chore...  Thank you all for your help
