Victron 75/15 for portable panel wiring
I’m finally getting around to wiring a Victron 75/15 for a 160w portable panel (no controller). I just want to be sure that I get this right because I’m a little confused by the “Load” terminals on the controller.
Is this right?
Positive side
Solar
SAE port > fuse > Victron controller > fuse > Battery
House
Converter > fuse > battery switch > Battery
Negative side
Solar Neg and House neg to Smart Shunt > Battery Neg
Is this clear? Does this seem right?
I’m at a campground with poor reception so having trouble searching for answers.
I don’t understand what would be connected to the “Load” terminals on the controller.
Thanks!
    edited February 2022
    Marceline, The Load terminals are for connecting devices that will draw piwer from the house battery/solar panels.  On some installations, the trailer 12VDC circuits are connected to the MPPT’s Load terminals, and if the power draw exceeds the available amps/watts, the MPPT will shut down the load to allow the battery to recharge.  I used this terminal to connect an external 12VDC plug on our TaB.  You can just ignore the Load connection for your installation.
    Have fun at the campground, wish I could have joined you…
  • MarcelineMarceline Member Posts: 1,631
    @Denny16 Thanks so much for your prompt reply! I’m at Olema this weekend if you want to swing by.
    I know, you mentioned in a previous post you were going.  Unfortunately work commitments prevent me from coming.  Have a grand time, and hopefully I will see you at the big meet up there later in the year.
