What kind of fastener is on the propane cover?
jkjenn
jkjenn Member Posts: 6,425
edited July 2015 in Trailer & Towing
And how do you remove it?
  • Mercator
    Mercator Member Posts: 237
    Looks like a rivet.
    Ray and Vida Barrick
    (formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
    Toronto ON Canada
  • R&DAndrews
    R&DAndrews Member Posts: 116
    Mercator said:
    Looks like a rivet.
    That's what I thought too.  Would you be able to replace it?
  • Nomad
    Nomad Member Posts: 7,209
    You drill rivets out don't you?
  • jkjenn
    Mercator said:
    Looks like a rivet.
    I winder how well the propane cover will hold up to drilling it out? I want to remove the PVC pipe.
  • Mercator
    jkjenn said:
    Mercator said:
    Looks like a rivet.
    No problem drilling it out. After the PVC pipe is removed you can put in another rivet.
    Toronto ON Canada
  • JandJ92010
    JandJ92010 Member Posts: 304
    Drill it out with a 3/16" drill bit. Remove the PVC pipe and then you replace the rivet with a new  3/16 rivet.
  • ChanW
    ChanW Member Posts: 3,165
    edited July 2015
    It's a "pop rivet".
    They sometimes spin when you drill them, so if you can, grab the other end with some vice-grips while you drill.
    Try to size your drill bit so it's just a tad larger than the shaft of the rivet. Then you can simply drill til the top of the rivet comes off, then push the rest of the rivet out of the hole. You shouldn't have to drill deeply at all.
     It's aluminum, so drill gently.
  • jkjenn
    Thanks, gang.
  • Rad
    Rad Member Posts: 516
    I drilled mine out, removed the rivets and then in a fit of OCDness I found the perfect size rubber grommet/plug in my parts bin.   I be silly sometimes =)
  • jkjenn
    I was already wondering what kind of plug would fit the hole, loll.
  • Rad
    Dats funny.  We are silly creatures
  • Spruce1
    Spruce1 Member Posts: 100
    Hi Jenn:  I removed the PVC tube by drilling out the rivets.  Be careful when drilling as the heat can (and did in my case) melt the plastic. It's not too noticeable but it did make the hole larger. Dave
    2014 T@B-S
    2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
    Minnesota
  • Rad
    Really? Are your drill bits sharp?  With a good bit mine took a few seconds to remove.  I'm sure you know this, others may not, you only drill out the very small center portion.
  • Spruce1
    Yes, sharp bits.  User error on my part.  I used too large of bit and the rivet started spinning.  I should of stopped, but... . Anyway, I learned my lesson and the second one came out much better.
    2014 T@B-S
    Minnesota
