What kind of fastener is on the propane cover?
jkjenn
Member Posts: 6,425
And how do you remove it?
Looks like a rivet.Ray and Vida Barrick
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada0 -
That's what I thought too. Would you be able to replace it?Mercator said:Looks like a rivet.0 -
You drill rivets out don't you?0
I winder how well the propane cover will hold up to drilling it out? I want to remove the PVC pipe.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
No problem drilling it out. After the PVC pipe is removed you can put in another rivet.jkjenn said:Mercator said:Looks like a rivet.
I winder how well the propane cover will hold up to drilling it out? I want to remove the PVC pipe.Ray and Vida Barrick
Drill it out with a 3/16" drill bit. Remove the PVC pipe and then you replace the rivet with a new 3/16 rivet.The HobbiT@B, 2015-L, towed by a2014 RAM C/V2
It's a "pop rivet".
They sometimes spin when you drill them, so if you can, grab the other end with some vice-grips while you drill.
Try to size your drill bit so it's just a tad larger than the shaft of the rivet. Then you can simply drill til the top of the rivet comes off, then push the rest of the rivet out of the hole. You shouldn't have to drill deeply at all.
It's aluminum, so drill gently.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya2 -
Thanks, gang.
I drilled mine out, removed the rivets and then in a fit of OCDness I found the perfect size rubber grommet/plug in my parts bin. I be silly sometimes
I was already wondering what kind of plug would fit the hole, loll.
Hi Jenn: I removed the PVC tube by drilling out the rivets. Be careful when drilling as the heat can (and did in my case) melt the plastic. It's not too noticeable but it did make the hole larger. Dave2014 T@B-S
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota0 -
Really? Are your drill bits sharp? With a good bit mine took a few seconds to remove. I'm sure you know this, others may not, you only drill out the very small center portion.Spruce1 said:Hi Jenn: I removed the PVC tube by drilling out the rivets. Be careful when drilling as the heat can (and did in my case) melt the plastic. It's not too noticeable but it did make the hole larger. Dave0 -
Yes, sharp bits. User error on my part. I used too large of bit and the rivet started spinning. I should of stopped, but... . Anyway, I learned my lesson and the second one came out much better.2014 T@B-S
Minnesota0
