We took delivery on our 2021 CS-S in march of 2021 and after the first few times out realized it wasn't really up for the boondocking we had in our 2009. I spent the summer getting the the idle battery drain to a minimum with switches and modifications. At the end of the season I started the process of converting to Lithium and getting all electrical to better support longer boondocking lengths.
Below is a list of what I put into the project up to this point. Going into 2022 season I don't have any more changes to make until I get some time on the system. I am especially curious what the Air8 use is possible on 280aH or possibly 560aH.
The asterisks are my rating on the purchase.
Charging Systems $927
Progressive Dynamics PD4060KV $122 on Amazon Renewed *****
Victron SmartSolar 100/30 $220 *****
Victron Temp Sensor $25 *****
Victron SmartShunt 500A $130.90 **** (Bluetooth power is weak, side connector is cheap)
Bluetti Power PV200 200watt suitcase panel $429 **** (Kick stand is light but not super strong, Expensive)
Supports second panel if desired.
280aH Lithium Battery $618
DALY BMS 4S 12V 200A $161.75 * (Returned to Amazon received wrong item and didn’t turn on easily)
RadioB BMS 4S 12V 120A $120 **** (Seems Better and cheaper than DALY)
Qty 4) VariCore 3.2V 280ah LifePO4 Batteries $467 - Aliexpress and only item not purchased from Amazon
Heltec Balancer $31 ***** - Probably not needed will unhook
Relocated to Passenger side Wheel Well storage. Wiring supports another possible battery bank
Pros
Temperature stable
Security stable
Tub storage is nice to have.
Cons
Loss of storage space inside
Inverter $199
Giadel 1200Watt Pure Sine Inverter $199 **** (Half power fan kicks on and gets warm)
2000Watt probably would have been better choice for cooling reasons.
Misc Fuses, Junction Blocks and cabling $295
Battery Kill switch $8
3/8 Power Junction Blocks $15
Qty 2) Victron Modular Fuse Holder $36
Qty 2)Victron 100A MegaFuse $15
10ft 6 Gauge Welding Cable with Lugs $39
10ft 8 Gauge Welding Cable with Lugs $34
10ft 2 Gauge Welding Cable with Lugs $63
Lug Crimpers $33 *****
Furrion Solar Port Inlet for RV $26 **** (Mounted next to Shore Power)
Generic Furrion to MC4 Adapter $26 *** (Doesn’t snap in properly but works)
Transfer switch items $101
16Amp Mini Circuit Breaker $9
20Amp Mini Circuit Breaker $9
30Amp 2 Pole DPDT Power Relay $65
Din Rail Terminal Block $9
Grounding Strip $9
Pros
Prevents AC from being back fed into inverter
Prevents unwanted AC drains during inverter use. Alde and Converter/Charger not tied to inverter A/C
All outlets and Air8 remain on Inverter or Shore power
Existing electrical mods for energy saving and function $359
MaxxAir 7000K MaxxFan $330 *****
Rocker Switches to turn off 12V on devices TV, Radio, USB Outlets $8 *****
Wired Step light to Porch light circuit ***** (Super Easy no reason not to do this mod for Bug deterrent and power saving)
Removed Propane safety solenoid $<10 ***** (Requires responsibility of turning off stove and propane bottle)
IR Remote extender $11 ***** extends remote stereo control to outside Clamshell
Items for convenience $
12volt to USB-C Laptop power supply.
12Volt Power Outlet, USB, USB-C Ports with switch Waterproof $20 Mounted on Tub replacing SAE port
Dewalt 12V/20V MAX Car Charger $109 (Drill, small 20volt Chainsaw, Fan) All chargeable from 12 volt outlets via Dewalt car charger
Repurposed Tub battery cables to 12volt outlet for charging portable electronics and dewalt 20volt charger
Tow Vehicle charging disconnected until DC to DC is added if ever needed
The Bluetti isn’t just watts double of the built in Solar. It charges at multiples of the built in
My guess is that if you were to double your Ah to 560; that you would be able to run the Air8 for 5 to 8 hours depending on set temperature, ambient temperature, thermal load, whether you have programmed the fan to run continuously or not, and the other variables. You may have issues with 1200 Watts when the compressor is starting that will require a soft start or possible a larger inverter.
Brad
Concord, NC
The Air8 fan pulls 12 amps @ 12volts continuous and I have that back to run with compressor. We run the MaxxAir to circulate inside and provide noise. I have already ran the Air8 a few times on the inverter it doesn't appear to have any issues with starting compressor so far runs @ 700watts with startup of 950 watts @ 12volts. I think a size up inverter (2000 watt) would be better though for the internal temp of the inverter. The inverter fan runs fast and continuous after it hits the 600 watts mark.
It really boils down to how hot outside and how often the Air8 needs to cycle along with how long the duty cycle is. If compressor only runs a cumulative hour during the night i'm going to be able to recover 60aH with Solar and Sun.
I have a logging device that will record inside and outside temperatures and also the Air8 duty cycle I will use during testing.
We are rarely in the camper during day so the plan in opening windows after dark running ceiling fan to cool inside down. After inside is same temp as outside then turn Air8 on to cool down and remove humidity. The unknown variable is what the duty cycle is at average summer temps we camp in.
Looking forward to 2022 season. Hopefully heading south early to get to warmer temps sooner.
Tom
2021 CS-S - Enjoying the new layout
2011 Outback 3.6r
Brad
Concord, NC
Tom and Deb
2011 Outback 3.6r
Like this but discontinued, unfortunately.
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
2011 Outback 3.6r
2011 Outback 3.6r
2011 Outback 3.6r
2011 Outback 3.6r
2011 Outback 3.6r
2nd 280aH Lithium Battery $501.64
JDB Smart BMS 4S 12V 120A $66.64 **** Aliexpress
Qty 4) VariCore 3.2V 280ah LifePO4 Batteries $435 - Aliexpress
Brings my total capacity
560aH Lithium Battery $1120 tested capacity 565aH
Next step is to weigh the batteries to compare to AGM/flooded battery weight
Pictures of cleaned up battery bay soon to follow.
2011 Outback 3.6r
With a standard flooded lead acid battery the solenoid alone can kill the battery in 24 hours.
2011 Outback 3.6r
