Already looking at the quiet times when Uteki is sitting in the driveway. Do folks remove their tank, leave it in the box and disconnect, or not even bother messing with it? Thanks.
John & Lori in Northern VA Former owner of 2015 T@B CS Max "Uteki" aka "H@wk T@B" 2012 Toyota Tacoma Double Cab 4x4 Off-Road "Zame"
Rad, how do you do the 110 hookup? We only have the 30 amp connection on Uteki, but would love to be able to do the 110. Are you using a converter connector?
Yes, it is an adapter you get that changes the layout of the prongs from 30Amp to 20/15amp. It is small and inexpensive.
Yup, "easy peezey lemon squeezey" as my 7 yr old granddaughter would say. You can run everything, however, if you run the Alde, do so on the lowest of the three electrical settings( the slide switch on the far left).
Hubby works for a propane company. I think he added gas once, so I don't know if he took it out or not. I very rarely use the propane, obviously. lol He says it's fine to paint the tanks as long as you use a color that reflects heat and no dark colors.
Sometimes I use it as a backup for my propane grill as well
Sterling, VA
For full disclosure I should state that I live on the California coast so the rig gets used year around.
Sterling, VA
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
ps...don't paint your LP tanks!
