jkjenn
Member Posts: 6,413
J.D. & Sue
Thanks, J.D. - I have not changed the battery box or added a platform, so I will be using angle to act as a platform as @normfun
and others have done. I am hoping that and solar will allow me to stretch boondocking a bit. I will report back.
I have 90 watts of solar and will need more. My decision was between adding more solar or improving the battery capacity, first. Since my first extended boondocking will come this fall, I opted for the extended battery capacity. I will probably be adding more solar, later.
Jenn
I'm sure you already found the youtube vid of the dual 6volts mounted inside a standard tab propane/battery box. Sorry, can't link right now, the guys "name" was Rallylsetta
Sorry, no direct exp, but my research indicated the Lifeline batteries are the top rated and super silly expensive, and the Trojan appeared to be the next in line. As you have found out, other brands like Interstate have been successfully used.
When I do mine I'm going Trojan.
good luck.
I should add that I have 6v interstate battery experience. I have a dual set in my wife's power chair. They produce a tremendous amount of power and move that almost 400lb chair at a brisk pace for a good amount of time.
I did did kill a set because I let the voltage drop to low and they would no longer take a charge. Since I replaced them I have heard there is a technique to bring them back to life that sometimes works. Moral is, keep them charged.
J.D. & Sue
I seriously considered this one. It gets very good reviews, from people who have Honda generators. http://www.amazon.com/WEN-56200i-Gas-Powered-Generator-2000-watt/dp/B00SMNLF4M/ref=sr_1_3?ie=UTF8&qid=1437002279&sr=8-3&keywords=wen+generator&pebp=1437002275739&perid=1BVQYXQAE4XYJK1Q68S7
The best price I found from the battery box was eBay.
I found the Trojan T-10 batteries for about $150 a piece from a local supplier who will deliver to my house.
Are you sick of my questions yet? How did you strap/bolt it down?
it says it ships in 3 to 8 months can that be true? Better order early.
Jenn
That Wen generator sounds like a great deal. The reviews sure are good. If I had known about the Wen when I was generator shopping I might have one now instead of the Honda. Be sure to keep us posted how you like it if you get one.
My Trojan batteries were delivered today. The total was $277 and Dan, the owner, was a really nice guy. I highly recommend them if you are in the Pittsburgh area and need batteries.
As as for generator noise, my Honda is waaaaaaaaaay quieter than my big Class C Onan generator was.
(Drawing removed so as not to confuse readers.)
